Sign in to follow this
Toecutter
Suggestions for electronic fuel pumps?
Hi, Any electric fuel pump will do as long as you use a fuel pressure regulator. Hitashi/su and Dellorto and Webers don't like more than 3 PSI. The trick is high volume ,low pressure so your not forcing fuel past the needle and seats.
Share this post
Link to post
Share on other sites
I've read that an early 80's carburated RX-7 pumps are good seeing they provide about 3.5 psi. I guess I might use one of these seeing I would'nt neeed to add a regulator to it.
Share this post
Link to post
i have a bosch pump i am trying to get rid of if you are interest
How much you want for it?
i piad 240 for it less than a year ago, i bought it brand new and it is still in the box
$180?
Share this post
Link to post
turns out the problem was with the choke. The car has'nt been started for years so just need to fiddle around with the carbs. thanx JB but luckily i won't needthe pump.
cheers
sulio
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
