OZ001 Posted January 7, 2009 Share Posted January 7, 2009 does anyone know the weight of the L28e engine out of a series 1 280zx?? Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted January 7, 2009 Share Posted January 7, 2009 A lot... Quote Link to comment Share on other sites More sharing options...
dalee Posted January 7, 2009 Share Posted January 7, 2009 Very helpful lurch Quote Link to comment Share on other sites More sharing options...
NZeder Posted January 7, 2009 Share Posted January 7, 2009 A lot... - does anyone know the weight of the L28e engine out of a series 1 280zx?? the question is a bit open - do you want to know with acc ie alternator, intake, exhaust manifolds connected etc. I don't know the correct answer but I have a book at home that states the L28 ie 179kg with the 432z's S20 engine coming in a 199kg, however this does not state if this is a bare engine or loaded. Quote Link to comment Share on other sites More sharing options...
OZ001 Posted January 7, 2009 Author Share Posted January 7, 2009 -the question is a bit open - do you want to know with acc ie alternator, intake, exhaust manifolds connected etc. I don't know the correct answer but I have a book at home that states the L28 ie 179kg with the 432z's S20 engine coming in a 199kg, however this does not state if this is a bare engine or loaded. thanks for that, i just need to know because im choosing an engine to be put in the 280zx but i wanna keep the weight abit low.. mainly because its for hill climbs.. was thinking about the 1UZFE out of a soarer but engine is abit too heavy.. Quote Link to comment Share on other sites More sharing options...
Zeddophile Posted January 7, 2009 Share Posted January 7, 2009 thanks for that, i just need to know because im choosing an engine to be put in the 280zx but i wanna keep the weight abit low.. mainly because its for hill climbs.. was thinking about the 1UZFE out of a soarer but engine is abit too heavy.. If thats the motor you want to use, a mate is putting lexus v8 into his toyota sprinter, and he swears black and blue that the v8 will weigh only a tiny bit more than the iron blocked 4cyl 4AC motor thats in it currently. I think he's deluded, but food for thought, since an l28 is also iron block and has two more cylinders, while the lexus v8 is all alloy.... Quote Link to comment Share on other sites More sharing options...
NZeder Posted January 7, 2009 Share Posted January 7, 2009 Don't let the all alloy fool you - have to seen how much a SR20 comes in vs other iron block 4 cylinders? Example SR20DET = 149KG a CA18DET = 128KG. And a FJ20ET is only 166KG and that is iron so only a few KG more for an engine that is almost bullet proof. So if you want to keep the weight down go for a turbo 4 cylinder these can get big power and torque when used with the right setup/parts etc. Or go the new Nissan QR25DE only 121KG then put a turbo on that or turbo a L20B the weight savings in the 2 cylinder vs the L28 will make up for the extra weight in turbo, intercooler etc and a L20B comes in at 137KG but then a non turbo FJ20 is 144KG and that would be a better choice so I say SR20DET or FJ20ET Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted January 7, 2009 Administrators Share Posted January 7, 2009 I want to see a 20B turbo in a 240z / 260z or 280zx . Light weight and awesome performance. Now that would be unique and I imagine a rotary weighs in alot less than a piston engine? Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted January 7, 2009 Share Posted January 7, 2009 Gav, an complete Chev LS1 is lighter then a complete 13BT... Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted January 7, 2009 Administrators Share Posted January 7, 2009 Really? I thought rotary engines were light weight? Since they are so small and didn't have all that valve train gear and conrods / pistons to worry about. Quote Link to comment Share on other sites More sharing options...
NZeder Posted January 7, 2009 Share Posted January 7, 2009 Yes but those cast iron plates add up + turbo's etc. I think a standard 13B non turbo is in at around 260lb = 118kg which is a lot given the size vs a L18 which comes in at the same weight. I think the newer 13B weigh more remember they have to use good high nickel iron for the end plates in a rota's so that makes the iron heavier. The atomic weight of Nickel is 61.3 (resent studies show this to be heavier than first thought of 58.7) and iron is 55.8 I did think about it at one point - but I was going to get a 4 rotor aka 26B in a 260z lol. However the cost of the custom shaft was $8000 then you need to get those housing both the cast end and sandwich plates then the alloy housing and high CR rotors, apex seals....so it would have been a $26-35 K engine but they sound great and the power ooh the power 500HP in NA form. Quote Link to comment Share on other sites More sharing options...
Mr240z Posted January 7, 2009 Share Posted January 7, 2009 I heard SSS automotive in sydney put a 20B turbo a couple of years ago I,ll find out...........!!! Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted January 7, 2009 Share Posted January 7, 2009 I heard SSS automotive in sydney put a 20B turbo a couple of years ago Into what? Orbit around Uranus? Quote Link to comment Share on other sites More sharing options...
sco_aus Posted January 7, 2009 Share Posted January 7, 2009 1UZs only weigh around 170kg and are a great engine. One of these would be an awesome conversion, do it. Quote Link to comment Share on other sites More sharing options...
RBZ 260 Posted January 7, 2009 Share Posted January 7, 2009 i got a 13bT out of S5 RX7 with gearbox. i can tell you it weighs heaps less than the RB20 without the turbo on it and no box using a manual winch. once i get to the 13bT for a rebuild ill put it on scale before dismantling it. rotaries have nice rev range but lack a bit in tourque at least feel wise. but S30 weighs lot less than RX4 and its pretty close to RX3. ive seen a pic of S30 with a 20b engine one of jap sites.so its been done.prob easy. As Zedevan said ill go SR20DET. heaps of tourque out of the little 4cyl. thats the most probable path ill go with my 240z unless i can grab a decent priced (CHEEEAP) RB26DETT. Quote Link to comment Share on other sites More sharing options...
NZeder Posted January 7, 2009 Share Posted January 7, 2009 Not that long ago there was an Autech RB26DE engine for sale here in NZ - if I did not have my RB25/26 hybrid engine from Japan I would have purchased it - $3999 NZD funny money would have got it and it had only done 73,000km here was the auction http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Nissan/Engines-drive-trains/auction-186522272.htm and here is a pic of the engine I got from the seller - I have his email still as I am sure this might not have sold (small market) Quote Link to comment Share on other sites More sharing options...
RBZ 260 Posted January 7, 2009 Share Posted January 7, 2009 Found this: http://www.funco-motorsports.com/motor_weights.htm if link fails here are details MOTOR WEIGHT COMPARISONS Subaru 2.5L N/A 285lbs. The motor mounts are 4 lbs Subaru 2.5L intercooled turbo 320lbs. The motor mounts are 4lbs. Northstar V8 n/a 510lbs. The motor mounts = 12 lbs Northstar V8 twin turbo 565lbs. The motor mounts = 12 lbs LS1 V8 n/a 480lbs. The motor mounts = 12 lbs LS1 V8 twin turbo 520lbs. The motor mounts = 12 lbs Honda 3.5L intercooled turbo 465lbs. Honda 3.5L n/a 430lbs. Mazda rotary 2 rotor, 285lbs Mazda rotary 3 rotor, 480lbs VW Stroker 2.3L N/A 260lbs. No radiator VW Turbo 2.2L 285lbs. No radiator, no intercooler (Rarely does anyone use a VW motor on a new sandcar anymore, we only include this for comparison) Radiator and cooling plumbing adds about 75 lbs for water cooled cars. i did find the site that Lurch mentioned about LS1 same weight as LS1. i had troubles believing it. so i searched bit more and found the yank site above.the figures above speak for them selves. true 13B has bit of plumbing but is so small. i got one and i still cant get over the size of the motor. its tiny. the 5spd gbox behind it is bigger and prob heavier. Quote Link to comment Share on other sites More sharing options...
RBZ 260 Posted January 7, 2009 Share Posted January 7, 2009 man RB26Dett is one damn sexy motor. get rid of it NZeder getting bad ideas and making bad decisions. Quote Link to comment Share on other sites More sharing options...
RBZ 260 Posted January 7, 2009 Share Posted January 7, 2009 man im on fire LOL L28 complete with stock manifolds, SU's, and A/C compressor + 5 spd 523lbs from this link at our friends at hybridZ http://forums.hybridz.org/showthread.php?t=97320 copy pasted some info incase link fails in the future CA18DET with trans 389lb SR20DET Complete + Five Speed 490lbs (source Sport Compact Car) Datsun L6 Alone + Four Speed toyota 1UZ-FE + R154 mission 486lbs + W58 mission 466lbs RB25DET Alone + Five Speed 700 lb complete RB26DETT Alone + Six Speed L28 complete with stock manifolds, SU's, and A/C compressor + 5 spd 523lbs 7MGTE complete with turbo and A/C compressor 515 lb w/ R154(125lbs alone) 640lb 2JZ-GTE Alone 594 lbs + Getrag Six Speed 746lbs VH45 508 lbs LS1 Alone + T56 Six Speed Chevy L98 Alone 540 lbs with iron heads, 510 lbs with aluminum heads + 4+3 OD Chevy LS1 459(automatic) 503(manual) LT1/LT4 562 (automatic) 620 (manual) LT1/LT4 Alone 562 (automatic) 620 (manual) ZF Six Speed Chevy SB (All Iron) Alone 575 lbs + T56 Six Speed Chevy SB (iron + Aluminum) 500 lbs + T56 Six Speed Ford SB (All Iron) Alone 550 lbs ? + T56 Six Speed Ford SB (iron + Aluminum) Alone 470 lbs? + T56 Six Speed Chevy BB (All Iron) 685 lbs + T56 Six Speed Chevy BB (iron + Aluminum) Alone 590 lbs + T56 Six Speed Viper 8.0 L alone 716 lbs + T56 Six Speed Viper 8.2 L alone 716 lbs? + T56 Six Speed toyota 1UZ-FE + R154 mission 486lbs + W58 mission 466lbs Quote Link to comment Share on other sites More sharing options...
Zeddophile Posted January 7, 2009 Share Posted January 7, 2009 DAMN IT! Was just about to post that one RBZ260. Note that it shows a 1UZFE with gearbox as weighing less than the L28 with gearbox. Theres another thread on HybridZ showing an L28 + box on scales weighing 539lbs, and somewhere about 400lbs seems to be the weight for motor alone.... Quote Link to comment Share on other sites More sharing options...
NZeder Posted January 7, 2009 Share Posted January 7, 2009 man RB26Dett is one damn sexy motor. get rid of it NZeder getting bad ideas and making bad decisions. no that is a RB26DE no TT just NA all the way and 260ps factory it was build but Autech and was in a 4 door 4WD Auto only R32. Look at that though a LS1 is the same weight as a 20B rota so they are heavy little pups really as the 20B is still not a large engine. Also don't forget that most of these weights might be based on stock engine ie cast headers/exhaust manifolds as put on a header (or new turbo manifold if a turbo car) and you can save 10kg Quote Link to comment Share on other sites More sharing options...
RBZ 260 Posted January 7, 2009 Share Posted January 7, 2009 no that is a RB26DE no TT just NA all the way and 260ps factory it was build but Autech and was in a 4 door 4WD Auto only R32. i though someone just removed the manifolds and turbos nevertheless. if i ever go the RB26 path it will definetly be twin turbo or one huge hair drier to replace the twins. Im a turbo nutter. i love my turbo lag, turbo/jet whine you know the (whoooooosh),the resulting shove in the seat and neck/head in the boot. . on a very expensive note how nice would the new GTR engine sit in aS30? all 485hp of it. hmmm got to keep an eye on damaged car auctions Quote Link to comment Share on other sites More sharing options...
sco_aus Posted January 8, 2009 Share Posted January 8, 2009 hehe, that'd be cool Quote Link to comment Share on other sites More sharing options...
Mick280zx Posted January 21, 2009 Share Posted January 21, 2009 So in the end (I'm not predicting this IS the end!) ..... All motors seem to have a consistant power/weight ratio? At some stage I was going to ask the same question that the original thread poster did... but there doesn't really seem to be any point chasing down a super light engine as even those with alloy heads/blocks are still heavy muthas! Quote Link to comment Share on other sites More sharing options...
NZeder Posted January 21, 2009 Share Posted January 21, 2009 hmmm light weight....turbo motorcycle engine but not in a car the weight of a S30.... Don't go too light either or the will upset the 52/48 balance too much. Anybody got an idea on what the 370Z 3.7l V6 comes in at? Or forget the weight of the engine and lose weight in the car via other methods. Item----------------Stock ------------- Fibre Glass--------------Carbon Fibre Bonnet--------------17KG---------------4KG----------------------?? Bonnet hinges---------3KG each side------Pinned 0.5kg------------?? Front guards----------??-----------------??-----------------------?? Then strip of all the sound proofing, underseal and other unwanted items (much like Nissan did with the factor 432R) heater, extra wiring, backets not needed, replace the glass with lexan/PC etc and get the car under 1000kg with a 350kg drive train that will make up for the weight of the engine Quote Link to comment Share on other sites More sharing options...
