Advice for an Amateur refitting SU carbs
108 replies to this topic
#81 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 21 June 2009 - 03:47 PM
LOL.  I have flash blindness from the light bulb going off over Stevo's head all afternoon!  All I did was act as brick wall to bounce ideas off.
Haha don't be so modest mate I would have been pretty screwed without your help.
Update:
My mechanic came over today and together we pretty much fixed everything.
The first thing he did was go over the entire car and ensure that it was fit to drive 1000km to Sydney. Apart from the rear tyres he gave it the thumbs up. Then we dropped the oil in the engine and replaced the oil filter at the same time.
After I had told him how good the engine was running the previous day thanks to Mike, it barely started and when it did it was backfiring out the exhaust and spitting out the carbs consistently. He said straight away: One of your cylinders ain't firing, lets check your plugs and leads.
All of the leads to the plugs were A-OK for resistance, but when he tested the coil->dizzy lead he found it had far too high a resistance. But replacing this did not fix the backfiring or spitting. He looked at the plugs and said, 'NGK HP6ES? You need hotter plugs!'. So off we went to supercheap to find some NGK HP4ES plugs. In the end they didn't have any in stock at supercheap or Repco but Repco had Bosch plugs that were equivalent to them so we got 6 of those. With these new plugs the engine ran much better with all 6 cylinders firing, the backfiring out the exhaust stopped and the spitting out the carbys stopped as well (or so we thought).
I then found that if the accelerator was engaged quickly the carbs would start spitting again. My mechanic cleaned the points and adjusted the 'dwell' to be the correct level. He then adjusted the timing from 8 degrees to 10 degrees advance.
After this the engine ran beautifully with no flat spots even at low RPM. We took it for a test drive and it felt like a new car. It still 'spat' once, but we were on a steep hill and at a low RPM. Otherwise I am very happy with the way it is running and hopefully it won't reset and run like crap tomorrow morning.
#82 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 22 June 2009 - 09:36 PM
Well after driving it today it drives beautifully when the choke is on, but when the choke is off the carbs begin to spit unless I accelerate really really slowly.
I am pretty certain that the carbys are binding (piston getting stuck or rising slowly), and are causing it to run lean and spit. I think I need to sand down the contacting surfaces between the pistons and the vacuum chambers on the carbys, and ensure that they fall at the same speed. I was gonna get some fine grit (between 1000-2000) and sand down the sliding surfaces.
Does anyone have any other recommendations about how I can stop the carbys binding?
#83 garvice
garvice
  • 1,037 posts
Posted 22 June 2009 - 09:58 PM
I think you just need to go fuel injection, this would have driven me nuts by now, especially since it is a daily driver.
#84 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 23 June 2009 - 06:24 AM
Haha yeah I did think about that. I've had to fix just about everything else so when I do get it sorted its going to run really well.
On a completely related note I dreamed you were parked at a shop I pulled in to in a green 240z which you had painted red with spray cans. I asked you why and you said you regretted painting it green. Then you got in a fight with the guy who pushed in line. I have weird dreams.  ???
Anyway, anyone got any ideas about fixing the binding issues?
#85 chris240
chris240
  • 2,208 posts
Posted 23 June 2009 - 07:55 AM
I thought you bought new SU's ? This is becoming a soap opera  :P
I had a local carbie guru install new su's on mine 2 years ago and theyve been perfect from day 1..
You "may" need to dyno-it once & for all, to get it running 100%....
Properly set-up SU's will give you less headaches than injection (there, I said it !!!)
#86 Zedback
Zedback
  • 283 posts
  • Tagline:Mike
Posted 23 June 2009 - 08:10 AM
That rear carby was definitely slower to descend and was the only one I saw spit.  It's also the one Steve got a little too "creative" with when cleaning.  200grit and precision machinery doesn't mix! :o  What qualification are you studying for again  ;D
Steve, I'd get the rim as smooth as you can with 800, 1200 and 2000 grit and then metal polish, unless someone has a better idea?  If that doesn't fix is then carby shop time.  When are you going to Sydney?  You could come around this weekend and we could try a different dashpot.  ???
#87 garvice
garvice
  • 1,037 posts
Posted 23 June 2009 - 11:31 AM
I'm a bit worried Steve. We have only met twice and I am already in your dreams. :-[
#88 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 23 June 2009 - 11:32 AM
hmmm I have a complete fuel injection setup sitting in my garage.....
#89 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 23 June 2009 - 12:33 PM
Haha yeah I must have missed the lecture on sandpaper grades. Damn! (until a few weeks ago I didn't know what a higher grade of sandpaper meant) It's funny how many basic things we don't get taught.
Haha don't worry, I think everyone from our Z meetings was there.
That sounds like a good idea. I intend to have a good crack at it this afternoon and tomorrow. Will let you know how it goes.
Damn you for that temptation. But seriously if I have this much trouble with carbys imagine the trouble I would have trying to set up EFI... eugh.
#90 Lynton
Lynton
  • 539 posts
Posted 23 June 2009 - 12:55 PM
Are you sure it is not ignition timing or a worn dizzy? By the way electronic ignition makes a huge difference IMO on the S30's. Lynton 8)
#91 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 23 June 2009 - 05:51 PM
Hey Lynton, yeah I went through all that with my mechanic, the timing is perfect and the car starts and runs beautifully with the choke in, the minute I put the choke off it starts spitting.
I just had a thought, if there was some misalignment on the needles the problem would be hidden when the choke was on because the jets would be lowered, and when the choke was off the jets would be rubbing against the needles again and causing friction. This rubbing would result in the pistons struggling to rise and would cause the spitting!!
I picked up 800 and 1200 grit sandpaper from bunnings, they didn't have 2000, and I will sand and then polish the contacting surfaces on the pistons and vacuum chambers until they both slide smoothly and fall at the same speed. When I reassemble the system I will do some drop testing and ensure they fall at the same speed. Then I will see if there is significant rubbing of the jet with the needle and if I can do anything about it.
#92 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 23 June 2009 - 10:32 PM
Ok I'm officially stumped.  :(
The carbys are tuned using colortune and unisyn, Mike will back me up when I say they are reasonably well tuned.
After my sandpapering efforts tonight, the pistons are falling at EXACTLY the same speed and are more free to move than before.
If anything, it has made the problem worse.
There just seems to be a flat spot at low RPM that if you try to accelerate through you will cause BOTH carbys to spit SIMULTANEOUSLY.
If I pull over and look into the mouths of the carbys and engage the throttle quickly, both of them spit fuel at the same time.
If the choke is on, the car runs reasonably well and does not spit out the carbys.
Anyone got any ideas?   :-[  :-\
#93 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 23 June 2009 - 10:53 PM
I don't know how it affects it but what about your compression test results?
140,150,115,110,120,110
Not the greatest, would this just effect overall performance or could it cause havoc on tuning?
I'm not sure about internals, maybe someone can put their 2 cents in, but what about checking valve clearances etc? Once again, don't know if this will have any affect on your problems...
#94 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 23 June 2009 - 11:02 PM
When we took those compression results we didn't know my car had barely any oil in it. Those centre cylinders were slightly higher compression after the oil was replaced.
Also, my mechanic said that he didn't think that those figures were low enough to be causing any problems. Not ideal, but yeah.
Hmm, perhaps fixing the falling speeds of the carbys requires me to retune them since the pistons don't require as much vacuum to rise?
#95 Zedback
Zedback
  • 283 posts
  • Tagline:Mike
Posted 23 June 2009 - 11:16 PM
Maybe not, at least they are both now consistent  :-\
I'm out of my depth here but try:
1. disconnecting and plugging the vacuum advance -> better/worse/no change
2. putting heavier oil back in the dashpots -> better/worse/no change
3. email Greg and ask him for contact details of Robyn or one of the other Z club qld guys who might know a mechanic who specializes in SUs
When we checked the timing the markings were dead steady so I don't think dizzy wear is the issue.  However when we checked the timing we did not disconnect the vacuum advance.  It was at about 8 degrees with vacuum advance connected, so could it be badly retarded.  SU Carburettor High-Performance Manual By Des Hammill states "Engines that do not have enough idle speed advance frequently 'spit back' while idling (backfire through the carburetor) and hesitate when initially accelerated, but then pick up and go."
Steve, did your mechanic set the timing with the vacuum advance plugged?
#96 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 23 June 2009 - 11:19 PM
I think he did.
What can I do to check if this is the cause? Increase idle RPM? Increase advance without vacuum advance connected?
#97 Zedback
Zedback
  • 283 posts
  • Tagline:Mike
Posted 23 June 2009 - 11:27 PM
Increase idle RPM?
That helped when we were messing around didn't it, probably worth trying as short term fix.  Hopefully someone with some more expertise will step in about now...  You could mess with the timing but you need a timing light, should have left you the one I had, I've got another.
#98 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 23 June 2009 - 11:30 PM
Yeah roger that I'll increase idle RPM and see if I can get a timing light from somewhere.
The other thing that might work as a short term fix is richening the mixture slightly, since engaging the choke somehow hides the problem.
#99 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 24 June 2009 - 11:53 AM
With both mixture screws richened by 1 full turn, and the idle RPM set from  ~700 to ~1000 the problem is significantly less noticeable. However when I'm doing hill starts it still spits and nearly stalls... It should be ok to drive to Sydney, but its just not as much fun as it used to be around town.
I wonder if Greg has a timing gun
#100 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 26 June 2009 - 01:50 AM
Car currently at Carb and Gas getting checked by Scott. He will see if he can diagnose what is causing the problem and let me know.
I noticed a red 240z with triple carbs in their workshop in very nice condition, does that belong to anyone on here?
