Help needed on How to adjust koni reds
26 replies to this topic
#21 Zedman240®
Zedman240®
  • 5,198 posts
Posted 07 January 2012 - 12:57 PM
Gareth, the yellows can only be adjusted for bump like the red's; reds have to be removed to be adjusted whereas the yellows are externally adjustable.
#22 Cozza
Cozza
  • 908 posts
  • Tagline:Datsun obsessed
Posted 16 January 2012 - 10:10 AM
Hi guys, here's something I found whilst perusing the Koni website, hope it helps.
http://www.koni-na.com/adjustment.cfm
Mick
#23 peter t
peter t
    OLD RETIRED Z FART
  • 1,816 posts
Posted 17 January 2012 - 04:59 PM
Thanks Mick, the shocks are a different type to McPherson strut type that fit Z's. I checked out the Konie site and have it all sorted now. Just have to go for a drive to get the feel of it then start on the front. Have set them on soft with lowered King springs so should give a good ride and not be like a go kart.
Peter
#24 peter t
peter t
    OLD RETIRED Z FART
  • 1,816 posts
Posted 13 February 2012 - 05:47 PM
The Konie reds I have for the front don't have the flat bit on the threads to hold in the strut tops to tighten up the nylox nuts. HTF do you tighten up the nuts. Not game to get the angle grinder to them ATM without some help from all you people that that may know better. :-\
#25 Roberto
Roberto
  • 740 posts
  • Tagline:No more sunroof's!
Posted 13 February 2012 - 07:40 PM
Do you have the screw cap? give us a pic.
#26 peter t
peter t
    OLD RETIRED Z FART
  • 1,816 posts
Posted 13 February 2012 - 08:22 PM
Will do when I get home at the end of the week.
#27 dazzed
dazzed
  • 409 posts
Posted 25 April 2012 - 02:35 PM
Don't the reds only adjust rebound, where as yellows adjust both bump and rebound equally?
yes thats correct  all rebound and hydraulic only not gas , yellows are gas , if i remember correctly Barry from top performance explained to me that the adjustment is only for when the valving wears out compensation adjustment if you dial in the firmest setting on a new shocker you will damage the valving from overheating, if you find the softest setting dosnt cope with the spring rate different valving is required ,ie , yellow sport konis, koni reds are a standard replacement shocker and dont last long cranked to their max setting out of the box hope this makes sense
