Performance camshafts for L28?
31 replies to this topic
#21 Glen
Glen
  • 494 posts
Posted 18 November 2008 - 08:57 AM
hello, thought i would dig up an old topic
im undecided on cam shaft, len is running 72 degree cam while im in favour of a 74 degree cam. Is there anyone running a 74 and what is the rpm range that it kicks in? lens (engine builder) 72 cam sounds almost stock. Im running 10/1 comp, flattops standard bore, balanced crank, and triple 40 carbs the head has been tidied up. inlet matched. F54/N42 combo
any advice
#22 260Coupe
260Coupe
  • 596 posts
Posted 18 November 2008 - 09:54 AM
Guys
You can try Camtech cams in NSW, thay had L6 billets in stock (well... six months ago) with quick response.
Check out the spec sheet
http://www.camtechca...m.au/?q=node/31
#23 Lurch ™
Lurch ™
  • 5,662 posts
Works style 74deg cam will work fine mate.
Should run to around 7k RPM depending on tune.
#24 reverendzed
reverendzed
  • 1,717 posts
  • Tagline:I'm Dave & Yes! I'm a real Revhead..er Reverend...
Posted 18 November 2008 - 10:10 AM
Lurch can you remember what we put in mine? it really kicks in at 3-3500 RPM
#25 Lurch ™
Lurch ™
  • 5,662 posts
Posted 18 November 2008 - 10:22 AM
It was supposed to be fairly mild, Dave.
25/65 65/25 timing, 270deg advertised Duration, 300odd thou. lift is what I suggested.
Weather or not it turned out to be that grind or not, I don't know...
#26 bluerat
bluerat
  • 540 posts
Posted 18 January 2009 - 03:16 PM
All right Gurus, I've got a couple of cams in stock, one stamped 487 and the other 479C, I was told the 497C was a 74 degree cam, can anyone confirm this and also do you know what the other is?......hold it.... the plot thick'ns I just checked in the shed, I purchased a downdraft L18 head a while ago, and it came with a spare, I was told, 76 degree cam stamped 487....does this all tie in?  Thanks
#27 Lurch ™
Lurch ™
  • 5,662 posts
Posted 18 January 2009 - 03:51 PM
It'd help if you new who it was ground buy.
Numbers dont mean shit otherwise...
#28 bluerat
bluerat
  • 540 posts
Posted 18 January 2009 - 04:35 PM
Sorry Lurch they came with the car, and the owner is no longer with us, the car was sponsered by Z spares, so I presume they came from there? if this is any help, I will do some more digging.
#29 bluerat
bluerat
  • 540 posts
Posted 18 January 2009 - 04:40 PM
Found them, the local Datsun engine guru uses wade cams, just looked them up, and guess what they match!! 479c is 76 degree and 487 is 72 degrees. fixed.
#30 dazzed
dazzed
  • 409 posts
Posted 18 January 2009 - 04:52 PM
sm needles flew out the door when premo unleaded was introduced , slowly over time tuning of cars has changed accordingly to the fuel available, there are cams available for efi which differ for carby application
#31 620Z
620Z
  • 1,710 posts
Posted 19 January 2009 - 07:48 AM
Grammer police on the grammer guru Lurch! New or knew. I am a hopeless speller myself but I got to get you sometime.  :D
#32 Lurch ™
Lurch ™
  • 5,662 posts
Posted 19 January 2009 - 09:00 AM
Yeah, you got me. I must have been overtired or doing 5 other things at once...
I didn't realize MachincPro84 = Dazzed. Why the name change Daniel?
Confused the heck out of me...
