280zx coilovers... or which one fits?
9 replies to this topic
#1 OZ001
OZ001
  • 535 posts
Posted 02 October 2008 - 04:26 PM
im just wondering what set of coilovers will fit on a 280zx that doesnt need any modification...
e.g would nissan S13 coilovers fit on a 280zx?
#2 luvemfast
luvemfast
  • 4,147 posts
Posted 20 December 2008 - 09:10 PM
The rears are an easy mod, but the fronts need more attention.
I did look into this at some point as I heard the same stories as you.
Put it in the too hard basket.
#3 OZ001
OZ001
  • 535 posts
Posted 27 May 2009 - 09:53 AM
alright i did some long hard research but this is all i came up with for the 280zx coilovers. (this is from my contact from japan) "apparently" DR30 RS turbo front coilovers or suspension fits into the 280zx front like a glove, most people in japan use the DR30 as a donor to the 280zx... my friend is trying to get photos but he lives on a different island :P . so my only problem is the rears, the problem with rears are that you have to get them modified or actually buy one thats actually made for the 280zx. well im still searching for more answers, i might be heading down to japan this year somewhere down the line... see what i can grab over there. if somebody knew this already and if this is a repost then im sorry and abit slow
#4 OZ001
OZ001
  • 535 posts
Posted 29 May 2009 - 09:28 AM
hi here's an update on suspension for the zeds. this is a japanese website.
http://translate.goo...html&hl=en&sa=G
#5 micks280zx
micks280zx
    Newbie
  • Pip
  • 8 posts
Posted 30 July 2009 - 07:02 AM
YES they will. I have done this mod.
The only bad point is that the ball joint is at a 45' angle so you can't lower it too much.
I should have some pics this arvo if you like.
#6 xa1973
xa1973
  • 666 posts
Posted 30 July 2009 - 09:31 AM
That would be good Mate.............
#7 micks280zx
micks280zx
    Newbie
  • Pip
  • 8 posts
Posted 30 July 2009 - 06:31 PM
What i did with mine was.
I used the std 280zx control arm and drag link. But you will have to work somthing out with the tie rod ends. There a tad bit short. I got S13 rose joints and made a adaptor from that to the rack end. Other wise its a stright bolt in.
Here are some old photos my camera shat it self today.
What you will see is S13 4 stud disk with a z32 caliper. Don't do this the caliper hangs 1/2 way off the disk. You might be able to use a larger disk with the 4 stud patturn. but i don't know what off.
i just got my self a S13 brake adaptor see here...
http://cgi.ebay.com/...sQ5fAccessories  )
and put on S14 hubs (There 5 stud 114.3 x 5) and put on 350Z disks (12.75" wide ones. NOT BREMBO) with the z32 calipers. I also used a S14 master cylinder (Becarful the front and rear lines are arse about to the std 280zx one) with a 1983 280zx brake booster.
I am trying to find a rear end of a S2 (1982 - 83) so i can do a rear 5 stud convert with a z32 rear calipers and Z31 disks. So that so be sweet.
Posted Image
Posted Image
Posted Image
Posted Image
#8 micks280zx
micks280zx
    Newbie
  • Pip
  • 8 posts
Posted 30 July 2009 - 06:39 PM
MORE PICS
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#9 aristo93
aristo93
    Newbie
  • Pip
  • 6 posts
Posted 31 March 2010 - 04:31 AM
hey mate i see what you did with the front but what did you do in the rear end. did you use s13 coilovers and do the same? also do u know if this mod will work on a 260?
#10 appsy
appsy
    Newbie
  • Pip
  • 1 posts
Posted 24 April 2010 - 10:10 PM
hey mate i was just wondering how the camber is and did it effect your wheel offset.
