oldmates260z Posted August 31, 2008 Share Posted August 31, 2008 My son's 260Z 2+2 is going thru rear tyres Put a set on Michellins on it thinking that he would get some more k's but worn them out in less than 20,000k Is this common? It does have a bit of rear end movement, not sure if that is related? He tells me he is not doing burn outs! Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted August 31, 2008 Moderators Share Posted August 31, 2008 Are they wearing across the whole tread width or just on the edges? If they are a soft compound tyre, they don't last long. If they are a plastic compound and last for 100,000k's, I'd be worried! Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted August 31, 2008 Share Posted August 31, 2008 I'd be having a look at the rear Toe settings... Quote Link to comment Share on other sites More sharing options...
chris240 Posted August 31, 2008 Share Posted August 31, 2008 Id be having a look at his local friday night hang-out...say 10.30pm..just look for the white smoke.. not doing burnouts.......oh yeah Quote Link to comment Share on other sites More sharing options...
fufu Posted August 31, 2008 Share Posted August 31, 2008 I'd have to agree with Sulio, it depends on the compound of the tires. The stickier they are the less they last. How ever it works both ways... the longer they last the less grip they have and ultimately is very dangerous, as it is slippery not only in dry but even worse in wet. With that being said, there's also lifetime of the tires. Stickier tires also fade and become less sticky (harden) over time. It's the matter of balancing which tires suits you best for your use. Quote Link to comment Share on other sites More sharing options...
oldmates260z Posted August 31, 2008 Author Share Posted August 31, 2008 Thanks guys, the tyres wear very evenly across the tyre, would they wear this way with a toe in issue? Can you adjust the toe in? Quote Link to comment Share on other sites More sharing options...
620Z Posted August 31, 2008 Share Posted August 31, 2008 Still go and get a wheel alignment and ask them to tell you how the rear wheels are. Zeds are natorious for not having the rear wheels in alignment. Wears out tyres fast and affects handling. Find out that then we can tell you how to fix reasonably simply. Quote Link to comment Share on other sites More sharing options...
oldmates260z Posted September 1, 2008 Author Share Posted September 1, 2008 Thanks, will get it checked as soon as the the boy has some money It will save him another set of rears I am sure. I would have hoped that Bob Jane's would have mentioned that when they fitted them the first time! Quote Link to comment Share on other sites More sharing options...
matt drago Posted September 1, 2008 Share Posted September 1, 2008 I just had a wheel alignment done on my '73 240Z (not sure if this also applies for the 260z's), but there is no adjustment for anything on the rear. And as you would guess, every possible measurement on my rears were out. I have done a bit of a quick search and found that you can get some modifications to make thing adjustable. I got Bob Jane to do the alignment for me. Just thought that I'd let you know. Cheers, Matt Quote Link to comment Share on other sites More sharing options...
620Z Posted September 1, 2008 Share Posted September 1, 2008 Yeah when I got mine done a few times the guys would always go and have a quiet word with each other and say nothning because there was no rear adj. But if they had of told me how far it was out I would have done something. Anyway there is a reasonably cheap fix to get perfect alignment. Let me know if it is out and I will sort you out with contacts for the fix. Quote Link to comment Share on other sites More sharing options...
nat0_240_chevZ Posted September 2, 2008 Share Posted September 2, 2008 first of all, bugger off the bj t marts, expensive 2nd rate tyres for just about anything. I use a place where the stocky and sell what ever you want not just a few particular brands and excludes the jap tyres. wheel aligntment i would say have a look at but it doesnt negate the fact, if they are driven hard without burnouts they will wear rapidly. simmple, if the wear is nice and even the id just say they have been used WELL ie pushing them but nothin toooo silly. I find michelins are quite soft & sticky when pushed therefore wear relatively quickly to the like of bridgies, yoki's etc. keep us posted wityh your findings... Quote Link to comment Share on other sites More sharing options...
Scoota G Posted September 2, 2008 Share Posted September 2, 2008 Then there is the expensive fix. http://www.arizonazcar.com/lowarms.html These ones have adjustment on both sides Quote Link to comment Share on other sites More sharing options...
