OFFSET
4 replies to this topic
#1 dazza
dazza
    Newbie
  • Pip
  • 6 posts
Posted 27 December 2005 - 01:26 PM
Can someone please tell me the offset for a 260z 2 seater?
I was told that if you don't have to right offset the car will bump steer. True or not?
#2 Zeddophile
Zeddophile
  • 987 posts
Posted 27 December 2005 - 03:43 PM
offset is about +12 for a zed. If you're looking for aftermarket wheels, pretty much the only thing is superlites, unless you run bolt on adaptors. The car can bump steer with incorrect offset, but I believe zeds are more prone to chew out wheel bearings.
#3 dazza
dazza
    Newbie
  • Pip
  • 6 posts
Posted 30 December 2005 - 03:08 PM
thank you :D
#4 Toecutter
Toecutter
  • 2,274 posts
Posted 30 December 2005 - 08:38 PM
Just curious. Over the years I've heard wheel offsets for Z being stated anywhere from -15 to +15. Most commonly I've read 0mm mentioned. I'm not all that concerned as I believe with a 7" wide rim you could fit anything from a -15 to +15 offset on a Z. What do the superlights come as when ordered for a Z because they seem to fit nicely, i think it might be 0. I personally like going slightly negative to fill those guards a little.
Sulio
#5 lambs
lambs
  • 131 posts
Posted 30 December 2005 - 10:40 PM
For a 240Z/260Z the 'ideal' offset for a 7" rim is 0 (zero).
