Sign in to follow this
ZD44TT
240z clutch kit fit 280zx gear box?
basically what I'm asking is if the centre hole in the 240z clutch has the same spline-thread count as the 280zx gearbox?
I've tried heaps of times to mount a 280zx gear box to the block with the 240z clutch kit bolted up but it won't mate up.
Motor is a L24.
hellppp : ).
Cheers.
Share this post
Link to post
Share on other sites
Should work fine.  Make sure the clutch is aligned properly.  Also, have the gearbox in a gear and try turning the output spline as you try to wriggle it in.
Share this post
Link to post
tried it again last night as I realised pressure plate thickness was different. still no fit. will try ur idea. thanks heaps.
Share this post
Link to post
You might have to change your thrust bearing carrier. There are at least 3 different thicknesses that I know of. Try to install the gearbox without that and see if it mates up then. If it does, look for another thinner carrier.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
