reverendzed Posted August 4, 2008 Share Posted August 4, 2008 Hi guys, being that I am now running a 5 speed and a fairly heavy cam I think it might be a good idea to change my diff out, I'm looking for a 3.9 if anyone has one for sale. Rev. Quote Link to comment Share on other sites More sharing options...
zedevan Posted August 4, 2008 Share Posted August 4, 2008 I have an R200 with what i believe is a 3.7 sitting around which i took out of my car (the factory 260z manual one?) a bit over a year ago and put in a 3.9 LSD - they have around a 500rpm difference per gear from what i could tell, and the speedo was read off by 10-15km/h? it had a bit of a whine off throttle which i've been told is normal. I heard they go for about $500, not sure if this is the case either? Quote Link to comment Share on other sites More sharing options...
Brabham Posted August 31, 2008 Share Posted August 31, 2008 3.7 or 3.9 goes for $500? I am also after a diff in Syd. Cheers Quote Link to comment Share on other sites More sharing options...
zedevan Posted August 31, 2008 Share Posted August 31, 2008 is that a question or a statement? assuming these diffs r in manual 2+2's it doesn't make a whole lot of sense huh? but then long nose r200's are used as an upgrade from smaller ones so... Quote Link to comment Share on other sites More sharing options...
Brabham Posted August 31, 2008 Share Posted August 31, 2008 Hi Zedevan, no it is a question. I believe 3.9s are probably worth more than 3.7s as 3.7s would have been more common. I am after a 3.364 from a manual 260 2 seater orig however $500 is a fair bit beyond my budget. Cheers. Quote Link to comment Share on other sites More sharing options...
