SUSPENSION DISCOUNTED PRICES FOR AUSZCAR MEMBERS.
14 replies to this topic
#1 Hunter
Hunter
  • 723 posts
  • Website:http://www.facebook.com/mankiniadventures
  • Tagline:www.facebook.com/mankiniadventures
Posted 09 July 2008 - 12:22 AM
A MATE I GREW UP WITH SENT ME THE FOLLOWING INFORMATION ON SUSPENSION. HE WORKS AT FULCRUM SUSPENSION BROWNSPLAINS QUEENSLAND. FULCRUM DO THE SUSPENSION ON V8 SUPERCARS AND MANY OTHER RACE AND PERFORMANCE CARS IN AUS.
I HAVE BROKERED A DEAL WITH JIMMY FOR AUSZCAR MEMBERS.
THE BELOW PRICES ARE A DISCOUNTED PRICE FOR SUSPENSION COMPONENTS. THIS DISCOUNT IS ONLY FOR AUSZCAR MEMBERS.
You and you're rare cars but I found some interesting gear that will make it out handle any Z in Australia.
OK your shocks are the hardest as they mainly use a non interchangeable unit, but we can work around it.
Option 1
Full set of konis classics they are and modified set of shocks to suit classic vehicles they are made to make to match up to new car shocks, so they even better than new car konis, these to be matched up to king springs.
Option 2
Send your struts up to us and we can customise a set of bilstiens into them with king springs, billys as far as I am concerned are the best shocks on the market, but we can only get a set for the front, they are not available for the rear. We would have to arrange a setup for the rear, anythings possible!!
Option 3
We can customise a full set of tein coilovers for your car, but if you go ahead with it we with have to liaise with you on some specifications on your vehicle. Also we will need your struts, when finished these would be full adjustable with dampening and bump, your height is also fully adjustable. Awesome unit but you will see in the price you pay for what you get.
PERSONAL CHOICE
Konis
Kings Springs
Front Adj Swaybar
Rear Race Spec Swaybar
All Poly Bushes
PRICES
240z
Shocks.
We have a few ranges of shocks but you can put a price on quality that’s why I quoted you on 2 different shock brands, first being kyb excellent replacement shock for standard to medium modified cars.
Second being koni, as far as I'm concerned without paying huge amounts of money this will be the best set of shocks available for the z series.
Kyb. Front $265 Rear $238
Koni. Front $551 Rear $551
Springs
are king springs, we have dealt with kings for years now and they are the best working springs on the market, plus they come with a life time warranty, so if there is every a sag or drop in rate they would be replaced, but its extremely rare that it happens.
Hell if v8 supercars use em why cant we!
King springs. Front $132 Rear $132
Sway Bars
We use Whiteline swaybars, same deal as king springs we know they perform well and haven’t had a problem, plus they are well ahead in the market of performance.
Front sway bar 24mm $256
Rear sway bar 18mm $256
Superpro poly bushes.
Bushes are a huge performer in any car, without half decent bushes your car is only running at 80% performance. Your wheels will not be in geometry with the vehicle therefore increasing tyre wear and even braking performance, steering fatigue and blah blah!
Here at fulcrum we have evolved a perfect blend of duro to suit your applications from racing to street cars.
Strut bar to chassis bushes $34
Lower control arm bushes $45
Diff to x-member $52.35
Any other requests for parts such as steering components e.i ball joints, tie rod ends, etc etc. just ring and ask for Jimmy.
260z
Kyb front $266 Rear $238
Koni front $551 Rear $551
King Springs front $ 132 Rear $132
Swaybar front heavy duty Adjustable blade 24mm $248
Swaybar front non adjustable 24mm $182
Swaybar Rear 70-74 adjstable 19mm $256
Swaybar Rear 74-79 adjustable 19mm $256
Swaybar rear 70-73 without OE bar 18mm $225
Swaybar rear extra heavy duty race bar
with Centre dip 22mm $225
poly bushes strutbar to chassis $34
polo bushes lower crtl arm inner $45
poly bushes diff to x-member $52.35
poly bushes front swaybar to chassis $18
poly bushes rear swaybar to chassis $18
280zx
KYB front $229 Rear $326
Konis not sure if available but will find some if needed
Kings front $132 Rear $132
Swaybar only rear available for this model but with some homework we can sort something out.
Rear bar heavy duty $182
Front lower control arm $40
Strut bar to chassis $34
Idler arm bush $12
Rear control arm lower $66
Z31, Z32, Z33
We have an extensive range for these vehicles as well ranging from tein coilover units to bilstein shock absorbers.
Everything I listed above is available for these vehicles as well.
CONTACT DETAILS
You must Deal through JIMMY at fulcrum suspensions, Browns Plains Store. THE OTHER STORE DOES NOT KNOW ABOUT THIS EXLUSIVE OFFER
http://www.fulcrumsuspensions.com.au/
darrenb@fulcrumsuspensions.com.au
Ph. 07 3800 7306
Mention you’re in AUSZCAR.COM and we will discount you on all retail prices.
#2 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 09 July 2008 - 03:36 AM
Hi mate,
Pretty cool that you went to all this effort on our behalf.
If others have positive experience with this shop and offer, please post back here. If there is really good feedback I'd consider making this post a sticky.
#3 Hunter
Hunter
  • 723 posts
Posted 09 July 2008 - 03:47 AM
No worries Gav.
I have noticed a few questions about where to get gear etc. Jimmy has organised some good prices for us and I am sure shipping charges will be very reasonable.
#4 Hunter
Hunter
  • 723 posts
Posted 13 July 2008 - 03:25 AM
Could someone give some interim feedback please, on how these prices compare to items they have bought off E-Bay or other companies?
#5 Toecutter
Toecutter
  • 2,274 posts
Posted 13 July 2008 - 11:23 AM
Hi Hunter,
I bought King Springs for my car ages ago. From memory they were 1 1/2" inch lower than stock and I paid about $230.00 for the four so the price above sounds good considering how many years have passed.
Can you give us some specs on say the Konis on offer and options on Kings ie how low will they lower the car etc, will fit stock strutts etc. (Always find people asking that question.)
Good Work
Sulio
#6 Lightmaster240z
Lightmaster240z
  • 1,610 posts
Posted 14 July 2008 - 12:03 AM
Hunter,
the price on the king spring are about $40.00to 80.00 cheaper than I can get localy
well done I hope these deal are well supported
regards
bruce
#7 mossy
mossy
  • 1,777 posts
Posted 14 July 2008 - 08:49 AM
I recently bought a 24mm whiteline front swaybar from autobarn for about $150 (20% off sale) but whiteline list their price at $177 so $256 doesn't seem right.
#8 Hunter
Hunter
  • 723 posts
Posted 16 July 2008 - 06:37 PM
Thanks for the feedback, We will see where this goes
#9 Hunter
Hunter
  • 723 posts
Posted 06 September 2008 - 09:02 PM
Sulio,  after chatting with Jimmy the springs will bring a 260z down 340mm (cwg) centre wheel to guard
and because every car obviously has differnet weights but if they needed a specific weight Jimmy can get kings to make custom coils
#10 Hunter
Hunter
  • 723 posts
Posted 06 September 2008 - 09:20 PM
mossy if you can find proof of that price post a link here and  Iwill see if Jimmy will match it.
#11 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 06 September 2008 - 10:40 PM
That price mossy is quoting makes sense, because he bought (im assuming) a non adjustable swaybar
The $256 is for a whiteline adjustable swaybar.
I think.  :-X
#12 Hunter
Hunter
  • 723 posts
Posted 07 September 2008 - 04:07 AM
Swaybar front non adjustable 24mm $182 .....This is the price of the 24mm non adjustable front swaybar they are not too far off the mark.
#13 mossy
mossy
  • 1,777 posts
Posted 07 September 2008 - 08:34 AM
Yep I got a non adjustable 240z front bar as that is all they made, the adjustable only came in the 260z bar.
You guys had better double check on the whiteline bars though as I just looked at their website and all the 240z and 260z bars are marked as discontinued.
#14 Hunter
Hunter
  • 723 posts
Posted 10 September 2008 - 04:25 AM
Speaking to Jimmy the front swaybar for a 240Z and 260Z are the same part.
#15 fufu
fufu
  • 423 posts
  • Tagline:NO NO NO!
Posted 25 March 2009 - 11:15 AM
Update:
Jimmy no longer works at Fulcrum. Whiteline no longer make these parts.
"Selby's" is the manufacturer for these sway bars . I just called them up and basically they use to work for Whiteline and now they've made their own company which deals with sway bars which no longer are produced by Whiteline. To get your hands on these go to your nearest Pedders and order.
So eg. the old whiteline code is BDF7 and BDR30 = SDF7 and SDR30
S for for their company name
D for Datsun
F for front
R for rear.
followed by the model number.
