RB30DET 240Z Circuit Car
308 replies to this topic
#21 Scando
Scando
  • 932 posts
Posted 30 July 2008 - 01:19 PM
Pics from the weekend
http://www.circlewor...SSRND4&start=45
http://www.circlewor...SSRND4&start=90
#22 Scando
Scando
  • 932 posts
Posted 20 August 2008 - 12:37 PM
I found myself a 2nd hand computer, a Haltech E6S.  It's very similar to the F9 I'm running except a few years newer and with ignition control which is what I was looking for.  It should do everything I need and was a LOT cheaper than buying a new one.  I think I'll leave it until the end of this season to install it though.
#23 Hunter
Hunter
  • 723 posts
  • Website:http://www.facebook.com/mankiniadventures
  • Tagline:www.facebook.com/mankiniadventures
Posted 21 August 2008 - 02:36 AM
What number is on your induction manifold?
Mine looks like this (not my car btw)
#24 Scando
Scando
  • 932 posts
Posted 21 August 2008 - 12:31 PM
I'm not sure of the number but I'll have a look.  It's just a standard Australian 280ZX manifold with the webbing cut out of it and the inlet modified to suit the larger throttle body.
#25 Hunter
Hunter
  • 723 posts
Posted 21 August 2008 - 07:07 PM
I thought the webbing was cut out.....That is what the difference is....I wasn't sure if it was another inlet manifold or modified.
#26 Scando
Scando
  • 932 posts
Posted 22 August 2008 - 05:21 PM
Makes it sooooo much easier to get the nuts tight on the manifold.  I remember getting the manifold onto my old R30 Skyline was an absolute nightmare!
In other news, my car is now engineer approved and registered on special interest registration  ;)
#27 Lurch ™
Lurch ™
  • 5,604 posts
Posted 22 August 2008 - 07:01 PM
Congrats Scando! ;D
PS, cheers for the webbing trick - might have to do that on mine.
You havent noticed any cracking?
#28 Scando
Scando
  • 932 posts
Posted 24 August 2008 - 12:19 PM
Might be able to come for a cruise with you guys on the next tassie tour now  :)
Haven't noticed any cracking.  The prevoous owner did the modifications on the manifold many many years ago so I assume it would have cracked by now if it was going to.  I think the webbing is there more as a heat sheild than for structual reasons?
#29 bluerat
bluerat
  • 540 posts
Posted 05 September 2008 - 08:34 PM
G'day mate, nice car you have there, I'm interested in how much rwKW does your Zed put out?? I love the colour, is it the same shade as Shrek??
#30 Scando
Scando
  • 932 posts
Posted 06 September 2008 - 06:26 PM
Yes, Shrek was where I got my inspiration from.  It puts out 3 rwkw to align with the 3 Shrek movies ;D
Glad to see you found your way here mate.
#31 Scando
Scando
  • 932 posts
Posted 06 September 2008 - 06:36 PM
Just found this video on youtube.  It's incar footage from one of the R32's I race against from round 4 race 1 at Symmons Plains following me.  You can all laugh at my massive understeer and then oversteer through the hairpin for the first couple of laps.
#32 Zedman240®
Zedman240®
  • 5,198 posts
Posted 06 September 2008 - 10:05 PM
Hahaha...didn't look that bad at all! That R32 catches up to you a couple of times under brakes. Great run though...should be great to see and hear some in car footage in your zed...I wish they had starts like that in the MSCA events.
#33 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 06 September 2008 - 10:48 PM
Scando that was sweet footage. I wish I could see it from your perspective as well  :)
#34 Scando
Scando
  • 932 posts
Posted 07 September 2008 - 08:57 AM
Yeah, looking at that I realise i was being a bit soft under brakes for the first couple of laps  ::)
The little cameras the guys are using are only $270 so I'm looking at getting one so I can post some in-car footage from the Z.  I've got a birthday coming up soon, might have to start dropping hints to family members  ;D
#35 bluerat
bluerat
  • 540 posts
Posted 07 September 2008 - 04:55 PM
Nice footage Scando, It's looks like it's on fast foward compared to my car!!!! Gee's those Targa A car's are quick!!
Three Kw.....three more than mine!
#36 Scando
Scando
  • 932 posts
Posted 01 October 2008 - 01:50 PM
Pics from the weekend:
Me:
http://www.circlewor...HQNAT&start=135
Mick:
http://www.circlewor...HQNAT&start=180
I had a good weekend, finished 2nd for my class and now have a decent lead in the series.
Had some great races with this Evo:
And this Commodore:
http://www.circlewor...9/HQNAT&start=0
Had a wet final and worked out a little setup trick to make the car work in the wet with the locked diff.  Was about a second a lap quicker than any other 2wd car including the cars in the class above me  :)
#37 PZG302
PZG302
  • 1,751 posts
Posted 01 October 2008 - 04:41 PM
Would that be the disconnect the front sway bar to really soften the front end up trick? That works a treat for me.
#38 Scando
Scando
  • 932 posts
Posted 01 October 2008 - 10:07 PM
That's the one  ;)
Last time I drove it in the wet it just wanted to go straight ahead at every corner with the welded diff.  With the front bar disconnected it was magic.
#39 Zedman240®
Zedman240®
  • 5,198 posts
Posted 01 October 2008 - 10:17 PM
Would you get the same effect if you had an LSD fitted? I'm sure the LSD behaves the same as a locked diff under power..
#40 PZG302
PZG302
  • 1,751 posts
Posted 02 October 2008 - 07:59 AM
Not really, with a locked diff even when you are under brakes it wants to push the car, where as most LSD's will effectively "freewheel" when not under power and will not push the car all the time.
A car with nuetral handling and open or LSD diff will have turn in understeer, and plenty of it, when fitted with a locked diff. To fix this I have set my car up accordingly, ie neutral handling with the locked diff. If I change to an open or LSD I would have to alter the set up my car so it won't be a huge oversteerer, not a small job as I don't have many adjustments. I'm a great believer in KISS and not allowing anyone to play with the car. I have it set up where I am happy with it and I can't really alter anything but shocks, as I run Koni adjustables and the general alignment, which is only checked and moved back to where it should be at the start of a season, or after a major off. My ride height is fixed by dropping the spring seats down the strut and re-welding them, giving me a fair drop in ride height, but still with the standard spring height and shock size to allow for effectively the full spring travel of a standard set up without carshing onto bump stops all the time.
For wet weather racing you generally a softer car, depending on the amount of water on the track and the time available to make the changes, I generally undo one side of the sway bay, I only run a front bar as I want the rear to wander a bit, and soften the shocks.
