gearbox or diff need your help???
5 replies to this topic
#1 mrp69
mrp69
  • 450 posts
  • Tagline:Peter
Posted 26 June 2008 - 07:40 PM
hey guys
my 240z has a 3.5l v8 with a supra 5 speed box in it and diff has just been changed to a r180 3.54 ratio.
the car is still reving very high in all gears for example in 5th gear at a 110km its reving at 5000rpm
what could be the problem
diff has been changed which i thought would of fixed the problem
could it be the gearbox??
any ideas need help
Peter
#2 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 26 June 2008 - 08:00 PM
Just a couple of questions.
What is the maximum speed in 1st 2nd 3rd and 4th?
What is the Highest speed you have had the car up to?
Is the speedo accurate?
Is the tachometer accurate?
This will give a better picture of what is going on. Also try to find out some more information on the gearbox and if you can, who did the conversion.
#3 Lurch ™
Lurch ™
  • 5,736 posts
Posted 26 June 2008 - 08:06 PM
Are you positive the new diff is a 3.54?
Also, how do you know the Tacho is accurate?
#4 mrp69
mrp69
  • 450 posts
  • Tagline:Peter
Posted 26 June 2008 - 08:07 PM
1st 40km 2nd 80km 3rd 100km
havent pushed it past that
and when in 5th on the freeway 110km 5000rpm
at 130km 6000rpm in 5th
speedo is accurate
tachometer im pretty sure is accurate due to the sound of the car and how loud it is
it might be the gearbox ratios im not sure but diff was changed
peter
#5 mrp69
mrp69
  • 450 posts
  • Tagline:Peter
Posted 26 June 2008 - 08:10 PM
diff was purchased off 240ZR (nick off this forum)
how can i check the tachometer??
#6 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 26 June 2008 - 08:27 PM
You can get a clip on one at most auto shops.
