L26 refresh - thought I'd share the results
42 replies to this topic
#41 Zedman240®
Zedman240®
  • 5,198 posts
Posted 20 March 2009 - 08:58 PM
I'm really interested in the results for the headers...Excellent write up Allan..
#42 PZG302
PZG302
  • 1,777 posts
Posted 22 March 2009 - 09:22 AM
I'll be a happy chappy if the drivetrain losses are up at 50%, 150rwhp for my old motor will give me 300hp, woohoo I can quote the same numbers as the other big boys ;D ;D
It will be interesting to see what the drivetrain losses are and what effects different components and condition may have, also different tyre, wheel and gearing combos can have.
I know tyre sizes can affect the final figures as can whether the gearbox is an auto or not as the torque convertor can act as a torque multiplier fo rthe dyno.
#43 260Coupe
260Coupe
  • 596 posts
Posted 23 March 2009 - 09:46 AM
Glen according to the "Dyno Guru" 34mm chokes should be good to flow 200 bhp and still provide good low down response (high intake velocity at low rpm) ....hence I reverted back to the 34's as the 37's made no difference in peak HP.
I should have the car back on the chassis dyno later this week to make a direct comparison between BHP and rear wheel HP....so the yard stick is 163 rw hp = 180 bhp...(initial results on chassis and engine dyno) .....so with 201bhp we should get around 180 rw hp or approx 135 rw kw .
Nothing else in the driveline has changed so apart from atmospheric conditions (air pressure and temp) it will be as close a comparison as possible.
