Replacement Solenoid Valve For Vacuum Source
6 replies to this topic
#1 Mike260
Mike260
  • 43 posts
Posted 01 November 2017 - 06:36 PM
Hi guys,
One of the items I need to remedy for my 260z RWC is my front defrost.
I've found the issue, a bad solenoid valve on the bracket in the bay that also holds the AC fast idle solenoid.
The coil in it is still good, but it barely opens and allows vacuum to pass.
I'll bypass it for now or swap it with the fast idle one, but does anyone know if spares are still available or if a good overnight soak in something can free them up?
Cheers!
Edited by Mike260, 01 November 2017 - 06:37 PM.
#2 PB260Z
PB260Z
    Peter (PB)
  • 3,292 posts
Posted 07 November 2017 - 05:39 PM
Hi
Can you post a picture of the solenoid in question ?
I may have some spare ones I could send your way.
PB
#3 Mike260
Mike260
  • 43 posts
Posted 07 November 2017 - 05:53 PM
Hi PB,
Appreciate the offer! Here are the two I have, do they look similar?
#4 PB260Z
PB260Z
    Peter (PB)
  • 3,292 posts
Posted 07 November 2017 - 08:04 PM
Hi Mike
I have a spare one of those.
I will test it and assuming it is OK will drop it in the post.
PM me your postal address and  it will be on its way to you.
PB
  • Mike260 likes this
#5 PB260Z
PB260Z
    Peter (PB)
  • 3,292 posts
Posted 08 November 2017 - 07:56 PM
Hi
Something else you may wantbto check is the one way valve near the vacuum tank.
Mine was stuffed. I replaced it with a windscreen washer one way valve, this valve is very small, fits inline and works well.
#6 Mike260
Mike260
  • 43 posts
Posted 08 November 2017 - 08:02 PM
Cheers Peter,
That's a good idea, I'll check it out.
You should have seen the mess the vac lines were in when I started.
The check valve was backwards and the vacuum reservoir was only before the fast idle actuator (vacuum to the heater core bits was direct from the manifold).
#7 PB260Z
PB260Z
    Peter (PB)
  • 3,292 posts
Posted 08 November 2017 - 08:15 PM
Yeah, been down that road twice.
Sorted mine out, then lined up to help another forum with the same challenge.
They can get very messy.
PB
