14Inch Tyres Best Option?
7 replies to this topic
#1 Brad
Brad
    Member
  • PipPip
  • 17 posts
Posted 24 July 2017 - 11:51 AM
Hi, I am just in the middle of putting on a new set of tyres onto my 280zx 14 inch alloy mags etc and want to know if I should put the original size 195x70x14s on or go to something wider which may handle better?? Anyone had experience or is it noticeable?  How wide can be fitted??
Thanks
Edited by Brad, 24 July 2017 - 11:52 AM.
#2 krizza
krizza
  • 35 posts
  • Tagline:Kris
Posted 24 July 2017 - 01:56 PM
Hi Brad, I had 215/65R14 on my 14x6.5 jellybean mags previously and I thought they were a good size / fit. Seeing as the 280zx can take even bigger rubber than the 260z I would go for that size.
Only downside is it is becoming harder to find decent rubber in 14", this was the main reason I moved up to 16x7 rims recently.
#3 gilltech
gilltech
  • Donating Members
  • 1,147 posts
Posted 24 July 2017 - 06:12 PM
Which 280ZX mag have you got? The one that was also fitted to 260Zs is 5.5" wide, but there were other designs used on the 280ZX that were 6". That will have some influence on what size you choose. If you go wide just make sure the front tyres don't hit the front valance panel on lock.
  • GongZ likes this
#4 dat2kman
dat2kman
  • 4,061 posts
Posted 25 July 2017 - 10:06 AM
Wider, will not handle better.
Run the next size up, if anything.
Stock was 185 ( series 1 ZX "iron cross" 5.5" design)
or a 195 if it was a Series 2 ZX rim ( 5 spoked 6" design)
Either a 195 or a 205 width tyre in a 60 or 70 series profile
If you want more grip, go to a 7" x15" and fit a 205/55 or a 225/50
Your rolling diameter will be close to standard.
#5 Brad
Brad
    Member
  • PipPip
  • 17 posts
Posted 27 July 2017 - 07:54 AM
Thanks guys for info they are the series 2 alloy wheels.
Does anyone have a pic of what the wheel nuts for them are supposed to lool like?
#6 dat2kman
dat2kman
  • 4,061 posts
Posted 27 July 2017 - 10:23 AM
Wheel nuts for series 1 & 2, also 260Z mag, are all same. The flat washers very in thickness, slightly.
If you need some, I can supply.
#7 AndBir
AndBir
  • 258 posts
Posted 01 October 2017 - 08:32 PM
Not sure if this qualifies as decent rubber however Dunlop have recently released a new tyre range the "Dunlop Sport Classic"
#8 Groundhog
Groundhog
  • 210 posts
Posted 02 October 2017 - 10:00 AM
There are some for sale on Ebay. The photos are useful for the size dimensions.
https://www.ebay.com...n=ps&dispItem=1
