External Mirror Id
13 replies to this topic
#1 George
George
  • 1,905 posts
Posted 19 July 2017 - 12:30 PM
Can anyone tell if this is a LH or a RH mirror?
I would love to compare it against an original so if anyone has a RH mirror in Sydney please let me know. I can come over most evenings or the weekend. PM me if you prefer.
Thanks!
  • RB26DETT likes this
#2 gav240z
gav240z
    Administrator
  • 13,232 posts
Posted 19 July 2017 - 02:45 PM
Best I can do for the minute.
It looks 'correct' from what I can gather.
  • George likes this
#3 RB26DETT
RB26DETT
  • 283 posts
Posted 19 July 2017 - 03:32 PM
Good score
  • George likes this
#4 George
George
  • 1,905 posts
Posted 19 July 2017 - 03:34 PM
Good score
Thanks to you sir!
I'm still not 100% convinced they are RH until I compare to an original though...
#5 George
George
  • 1,905 posts
Posted 19 July 2017 - 04:01 PM
As I've suspected, it appears to be a LH mirror.
As you look at the mirror, the stalk leans to the right from the base. RH ones should lean to the left.
Hard to tell from the photo you posted Gav but yours looks to be a LH one as well...?
Peter provided this photo he took just now. Plated stalk is a LH unit he purchased from the States. Unplated is the original RH one from his car.
#6 RB26DETT
RB26DETT
  • 283 posts
Posted 19 July 2017 - 04:28 PM
Oh! When i receive mine in the post I will compare it to the one from my 72 car.
#7 gav240z
gav240z
    Administrator
  • 13,232 posts
Posted 19 July 2017 - 05:07 PM
I just don't see your mirror would work on a LHD door?
Here, for example is a LHD mirror.
#8 Brabham
Brabham
  • Donating Members
  • 1,060 posts
Posted 19 July 2017 - 05:51 PM
Does yours have a part # George?
#9 George
George
  • 1,905 posts
Posted 19 July 2017 - 08:43 PM
I just wrote a long reply and hit the back button on this silly mouse I use. Here we go again, a bit more succinctly.
You might be confused by the mirror part being angled for the RH side. I did that thinking it was a RH mirror. It can swivel all the way around to it's correct LH side position.
The main difference I've realised is the stalk angle to it's base. Looking at the mirror face, the RH one leans to the left (towards the car) and the LH one leans to the right (again, towards the car).
The mirror head swivel is a clever design if only the stalk was 90 degrees to the base. Sadly they deemed it important to design it at a different angle and cursed us all to waste our time searching for unicorn poo.
I personally don't see too much of an issue with the LH mirror on the RH side other than that OCD thing bugging me.
Here are a couple of helpful photos with what looks like correct mirrors on correct sides. Note the stalk to base lean angles (bend your head to the base horizontal and it becomes obvious).
Alex, that is what got me thinking it's the wrong one.
The part number on the box says 96301-E4600 which a quick Google search will take you to a variety of US LH side mirrors.
After some digging around I found the Australian RH door part number is actually 96302-E8800 but good luck finding that. Part 96301-E4100 is the Europe equivalent.
See here:
For reference sake here is a US manual with the part number 96301-E4600 - http://www.carpartsm...finish-arm-rest
#10 260z blues
260z blues
  • 102 posts
Posted 30 July 2017 - 10:56 PM
I have been looking to see if my 260z has factory mirrors or aftermarket parts and unfortunately is not original so great thread to find.
My ta22 celica has similar design mirrors that are designed with a slight (although more noticeable than the zed ) angle to be non interchangeable each side.
So now that i know i need a pair of new mirrors for my 260z is there anywhere in particular to find either side or are these becoming rocking horse poo items ?
#11 russandra
russandra
  • 48 posts
Posted 03 March 2018 - 07:23 PM
I know this is an old post but bear with me.
When I bought my car 3 years ago it had a right hand mirror attached but the mirror head broke and was dented and somehow was lost, but the stalk is still attaced to the car. Question is, are the left hand heads in the states the same shape, if they are I might be able to flip the head 180 and attach it to my stalk. Does anyone know if this can be done?
#12 gav240z
gav240z
    Administrator
  • 13,232 posts
Posted 03 March 2018 - 07:49 PM
Yes it should be possible to do that without issue.
#13 Cozza
Cozza
  • 1,085 posts
  • Tagline:Datsun obsessed
Posted 04 March 2018 - 06:18 AM
Looking at the pics above, it looks like the stalk is fixed to the head slightly above the horizontal centreline of the head. I figure this means that when you flip one around to use on the other side of the car, it will now fix to the stalk slightly below the horizontal centreline of the head.
Have you found left hand mirror heads and, do you know if they are easily separated from the stalk?
#14 PeterH
PeterH
  • 240 posts
Posted 04 March 2018 - 09:25 AM
These photos are the heads of my original 1973 car right side mirror and a left side mirror that I bought from the US. The right side mirror is on the right hand side of both photos.
The head is held in with a screw ....you need to remove the glass to access it. I managed to ease the glass out of one and broke the other one ( seven years of bad luck ) and had a couple of replacements cut by the local lead light glass man.......less than ten dollars .... and he also beveled the edges for refitting.
Hope this helps
Pete
Edited by PeterH, 04 March 2018 - 09:26 AM.
  • GongZ likes this
