Wanted To Borrow - Fuel Sender Removal Tool
4 replies to this topic
#1 aircobra
aircobra
  • 650 posts
Posted 11 July 2017 - 12:42 AM
does anyone have one ? my unit is in real tight and i don;t want to wreck it screwdriver bashing
thanks in advance
#2 ScottyD
ScottyD
  • 122 posts
Posted 11 July 2017 - 12:40 PM
If you can't get one try to make one
http://woodworkerb.c...240z-fuel-tank/
#3 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 11 July 2017 - 04:59 PM
thanks in advance
Large brass punch and just give each tab a good solid hit and it will move.
#4 aircobra
aircobra
  • 650 posts
Posted 11 July 2017 - 09:01 PM
that did it. because the car was standing for a long time, had some corrosion on the wire terminals on the inside of the sender. would have to be the world's simplest device - just a coil of wire and a brass slider.
some carb fluid and an acetone soak fixed it
saved $100 for a new one. getting closer to finishing every day
#5 260DET
260DET
  • 2,153 posts
  • Tagline:Tribal Elder
Posted 12 July 2017 - 08:03 AM
It's normal practice with anything like that on an older car to hit it with some penetrating oil first.
