Wanted Carb Cable Clamp
16 replies to this topic
#1 cracker
cracker
  • 451 posts
  • Website:http://www.projectedpm.com.au
  • Tagline:James
Posted 07 July 2017 - 12:36 PM
Hi All,
On the hunt for one of these - pic attached. No idea what it would be worth but happy to pay of course.
#2 Agno
Agno
  • 1,337 posts
Posted 07 July 2017 - 01:47 PM
Could a P-clip from Jaycar or Bunnings do the job or are you chasing originality?
#3 600Z
600Z
  • 290 posts
Posted 07 July 2017 - 03:06 PM
If the later flat top carbies have the same clip I'd have one, though won't be able to check for a couple of weeks.
Justin
#4 cracker
cracker
  • 451 posts
  • Tagline:James
Posted 07 July 2017 - 03:11 PM
I'm sure they would do the job, but yes originality is key. Currently cable ties are actually doing the job nicely! Ha..
Justin
Thanks Justin, I'm actually not 100% on this! I'll do some research, or another member may be able to chime in with info. Cheers
#5 gilltech
gilltech
  • Donating Members
  • 1,305 posts
Posted 07 July 2017 - 05:47 PM
Just make one, seeing as you have one to copy.
#6 OdinZ
OdinZ
  • 292 posts
  • Tagline:I run faster than my Z
Posted 07 July 2017 - 11:11 PM
Are you talking about the little screw/clamp at the end of the choke cable or p-clamp looking things? i am also looking for both items.
#7 aircobra
aircobra
  • 762 posts
Posted 11 July 2017 - 12:40 AM
lurch can probably fabricate something for you. otherwise mission impossible
#8 cracker
cracker
  • 451 posts
  • Tagline:James
Posted 11 July 2017 - 08:58 PM
Looking like the best (only) option!
P clamp.
  • OdinZ likes this
#9 Chassis254
Chassis254
  • 60 posts
Posted 12 July 2017 - 03:21 PM
James you also need to know which one you want as there are 2 different ones per carb set. They are marked 1 or 2. From memory 1 is for the front carb and 2 is for the rear carb.
  • cracker likes this
#10 cracker
cracker
  • 451 posts
  • Tagline:James
Posted 13 July 2017 - 10:52 PM
Jeepers! Okay.. the plot thickens. Thanks
#11 GTI-Z
GTI-Z
  • 81 posts
Posted 15 July 2017 - 02:20 PM
Had a look at a couple of old flattops sitting in the back of the garage. I think they were both off the same car.
Someone correct me if I am wrong but these 260 flattops have the choke mechanism on the RHS of both carbs, whereas the 240 carbs are RHS on the front carb and LHS on the rear carb.
The screw that holds the P onto the bracket appears to have a captive screw.
If so, I have a couple of No. 1's available.
#12 cracker
cracker
  • 451 posts
  • Tagline:James
Posted 15 July 2017 - 02:31 PM
I'll check what number mine is this afternoon and shoot you a PM. Cheers!
#13 gilltech
gilltech
  • Donating Members
  • 1,305 posts
Posted 15 July 2017 - 02:43 PM
Agree, flat-tops on same side whereas round-tops are LH & RH.
#14 GTI-Z
GTI-Z
  • 81 posts
Posted 16 July 2017 - 09:09 AM
Just had another look at the clamps.
The 240Z clamp is 21 mm long whereas the 260z flattop clamp is 26 mm long.
It appears that the flattop clamp has a longer adjustment slot for the screw.
#15 GTI-Z
GTI-Z
  • 81 posts
Posted 16 July 2017 - 01:12 PM
Looks like the brackets that the P clamp attach to are quite different from the 240 to 260 carbs (240 on left)
#16 GTI-Z
GTI-Z
  • 81 posts
Posted 16 July 2017 - 09:35 PM
Just had a closer look at Cracker's original picture and it appears that he has 4 screw carbies.
It seems that the three screw carbies have an entirely different choke cable clamping mechanism to the later carbs.
The 260 flattop's P clamp and plate is somewhat similar to the three screw roundtops.
So it appears that the P clamp off the flattops are only good on the three screw carbs. :  :  :   Be nice if someone could confirm this.
Brad
#17 cracker
cracker
  • 451 posts
  • Tagline:James
Posted 16 July 2017 - 10:15 PM
Hey Brad,
I've had another confirmation of the types, and do believe these are "4 screw carb" only clamps - so appeared on 70-71 only.
As Chassis254 has mentioned previously these are also stamped 1 & 2. I have the "2" clamp currently, which comprises a backing plate (one piece) and 2 separate "P" pieces, one slightly larger than the other.
James
