Sign in to follow this
260z.76
Rb25Det Custom Made High Volume Sump For 240Z
Custom sump made for datsun 240z 260z or 280z to put a skyline rb25 turbo engine in clearing all steering and crossmember. May fit rb20 and rb26
High volume sump brand new never used
May come with oil pick up pipe for the right price
Pick up redcliffe 4020 can post
$800 neg
Edited by 260z.76
Share this post
Link to post
Share on other sites
Going a different route gana keep the standard engine rather than rb.
I forget the volume ill try to find it out tomorrow from memory its 1lt more than standard.
I mounted on but never put oil in it but has had the welds leak tested and no leaks were found.
Share this post
Link to post
Does the sump sit above or below the front cross member? If below - that 90 degree right angle bowl face is just asking to be torn apart on a bump -  I should know, mine did, and its of legal height. Should have a 45 degree front face to slide rather than  dig in.
Share this post
Link to post
It sits like half way down crossmember from memory. Should be fine or just tacweld a slide plate to it
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
