Wtd 260Z Manual Pedal Box
7 replies to this topic
#1 260z blues
260z blues
  • 87 posts
Posted 19 June 2017 - 11:05 PM
Trying to find parts for my 2 seater 260z to do trans conversion.
Figured would start with pedal box but if you have other parts would be great also.
Cheers.
#2 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 20 June 2017 - 08:52 AM
I have clutch ( basically new less then 20km on it ) flywheel and tail shaft?
$200 the lot
#3 theremm
theremm
  • 393 posts
Posted 20 June 2017 - 11:20 AM
Auto and manual pedal box are the same. You just need to get the clutch pedal and manual brake pedal (the pad is smaller than the auto pedal)
#4 44014
44014
  • 817 posts
Posted 20 June 2017 - 12:55 PM
Dont even need the manual brake pedal, You can cut it to a smaller size and fit the manual brake pedal rubber over that.
You can even cut it to the right a bit makes it easier to heal toe :)
#5 260z blues
260z blues
  • 87 posts
Posted 22 June 2017 - 11:12 PM
Thanks for the info guys.
So looking for clutch and brake pedal then lol.
Would rather not cut up the one i have. Might work but i would know it wasnt 100% correct and that would bother me after awhile.
#6 Lurch ™
Lurch ™
  • 5,605 posts
Posted 23 June 2017 - 09:07 AM
Les Collins Racing sells complete manual conversion kits: pedals, new master & clutch cylinders with line, flywheel / clutch assembly, fork & TO bearing as well as a reconditioned gearbox of your choice.
03 5623 3108
#7 260z blues
260z blues
  • 87 posts
Posted 27 June 2017 - 11:41 PM
Thanks.
Am awaiting info and price from lcr
#8 twoforty z
twoforty z
  • 115 posts
Posted 01 July 2017 - 09:37 PM
2x pedal boxs on gumtree in Adelaide. $50 a piece
  • CraigZ likes this
