Slide Hammer For 260Z Rear Lca
5 replies to this topic
#1 timtim
timtim
  • 33 posts
Posted 19 June 2017 - 09:34 AM
Hi Guys
Anyone in NSW have this tool which i can borrow my friend just told me its a slide hammer, "if you let the guys know your trying to pull the bolt out from the part which connects the rear strut to the outter LCA they'll know what your talking about"
#2 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 19 June 2017 - 09:38 AM
Good luck. I suggest purchasing a drill press, A range of drills leading up to 22mm and a press. And a hacksaw...
#3 PeterAllen
PeterAllen
  • 1,340 posts
  • Tagline:Manana!
Posted 19 June 2017 - 10:13 AM
If you're referring to the Spindle Pin, then I've made one and I'm in Sydney.
PM me.
#4 gilltech
gilltech
  • Donating Members
  • 1,147 posts
Posted 19 June 2017 - 12:24 PM
Ditto 44014.
A slide hammer will only work if the spindles are lightly bonded to the bushes. Anything more and more drastic measures are req'd.
#5 dat2kman
dat2kman
  • 4,061 posts
Posted 19 June 2017 - 06:28 PM
Sometimes you can be very lucky, and the spindle pin puller will work fine.
A little bit of heat, ie hand held butane torch, can help a lot!
#6 RLY240
RLY240
  • 243 posts
Posted 19 June 2017 - 08:35 PM
I've also found that swift hammer blows to the body of the upright can help break the bond in the same way you can get a tie rod end out of a steering knuckle.
Still needs a press or puller though.
Roger
