Metal Cladding Fuel Hoses
7 replies to this topic
#1 260DET
260DET
  • 2,280 posts
  • Tagline:Tribal Elder
Posted 13 June 2017 - 10:31 AM
For the project race car, the fuel cell has been located directly under and up against the rear floor so the filler hose has to come in through the rear quarter panel above the floor into the top of the cell. Is there any simple way to clad it, as far as I know there is no suitable off the shelf clad hose available. For venting I'm assuming that braided stainless fuel line will be OK.
There is a good reason for mounting the cell up against the floor, that's not going to be changed. So, solution?
#2 Groundhog
Groundhog
  • 211 posts
Posted 13 June 2017 - 12:21 PM
These guys maybe able to help.
http://techflex.com....ndable-sleeving
#3 nizm0zed
nizm0zed
  • 1,312 posts
Posted 13 June 2017 - 08:59 PM
How much do you have to cover?
is it a reasonably straight piece of pipe?
its probably pretty simple to bend up a bit of alloy sheet into a U shape and screw it down over the top of it.
It'd protect it from any debris that may end up loose in the event of a spill and it'd also work well to maintain the firewall between the fuel system components and the cabin.
#4 garvice
garvice
  • 1,037 posts
Posted 14 June 2017 - 06:34 PM
Look up annaconda conduit. Might not get it large enough though.
#5 garvice
garvice
  • 1,037 posts
Posted 14 June 2017 - 06:37 PM
http://www.schnap.co...tal-conduit-en/
Can also get specifically liquid tight options too but it won't be cheap.
#6 garvice
garvice
  • 1,037 posts
Posted 14 June 2017 - 06:39 PM
Another option is the dual wall tubing they use for fuel pumps. Can't remember the name off the top off my head.
#7 garvice
garvice
  • 1,037 posts
Posted 14 June 2017 - 06:41 PM
But I reckon making a new rear firewall is the easiest/cheapest solution.
#8 260DET
260DET
  • 2,280 posts
Posted 15 June 2017 - 08:20 AM
Thanks for the options blokes.
