Deceleration Popping At Tailpipe With New Msa Premium Exhaust System
32 replies to this topic
#21 jalexquijano
jalexquijano
  • 61 posts
Posted 24 May 2017 - 01:06 PM
ill try this once again! i thought if i used a pertronix 1761 ignitor module, i should gap them at .035 instead of .031??
#22 scott
scott
  • 199 posts
Posted 24 May 2017 - 04:25 PM
i keeped bp6e with pertronix on stanard gap, done around 10000km on that setup. plug as stated looks lean but the popping sound is something you will have to live with. You need to check your O2 readings really to get the most out of it.
#23 jalexquijano
jalexquijano
  • 61 posts
Posted 25 May 2017 - 02:17 AM
so it does not do any effect if i gap them at .031 instead of .035?
#24 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 25 May 2017 - 09:09 AM
That is such a small difference you will never notice, You actually want the biggest gap you can possibly run, I would run a .5 gap.
Its only when talking high hp turbo cars that you run into issues with bigger spark gap.
#25 jalexquijano
jalexquijano
  • 61 posts
Posted 26 May 2017 - 12:34 AM
you mean .035 gap??? NGK BP5ES???
#26 Cozza
Cozza
  • 1,022 posts
  • Tagline:Datsun obsessed
Posted 26 May 2017 - 06:58 AM
I don't think plug gaps are your problem, I also don't think the gaps you are talking about (.031 & .038) will make much difference. But, the upgrade of your pertronix system over points is not the only factor in plug gap. The plug gap needs to be crossed by the spark which is generated by your coil. If your coil isn't up to the job you need to reduce your plug gap.
Plug gaps vary for a bunch of reasons but have a read of the link it is pretty well described.
http://www.gsparkplu...g-gap-settings/
With regards to your popping and stumble at idle, read all the advice already given to you again. It seems that everyone here suggests you alter your air/fuel mixture. This advice is mainly due to the colour of the plug pics you have posted.
#27 Lurch ™
Lurch ™
  • 5,691 posts
Posted 26 May 2017 - 07:16 AM
I feel this video sums up this thread adequately:
#28 Cozza
Cozza
  • 1,022 posts
Posted 26 May 2017 - 08:00 AM
Pretty sure that's Gav on the guitar.
#29 jalexquijano
jalexquijano
  • 61 posts
Posted 27 May 2017 - 07:20 AM
Well ill increase the gas mixture to 3.5 turns clockwise to see if there is any effect on get the plugs richer. By the way, my coil is a pertronic 1.5 ohm flamethrower coil compatible with the petronix 1761 ignitor module.
#30 Cozza
Cozza
  • 1,022 posts
Posted 27 May 2017 - 12:12 PM
Read my earlier post an others again.
By winding your screws down will definitely richen your mixture at idle but maybe not at cruise or wide open throttle where the mixture is critical.
I'm not suggesting the needles are worn, I'm suggesting they are not the right needle for your engine.
The needle is like the fuel jets on a Weber type carb. The taper on the needle regulates the amount of fuel that passes through the carby for a given piston/damper position.
I think your needles may be too lean for your engine setup.
#31 jalexquijano
jalexquijano
  • 61 posts
Posted 01 June 2017 - 07:53 AM
Which needles do you recommend?
#32 d3c0y
d3c0y
  • 2,950 posts
  • Tagline:Forum Jerk
Posted 01 June 2017 - 08:54 AM
I recommend taking your car to a dyno so you know what your fuel mixtures are actually doing.
#33 jalexquijano
jalexquijano
  • 61 posts
Posted 19 July 2017 - 11:40 AM
I just remember that i bought this car it used to have the MSA TWICE PIPES set up and it never caused any deceleration backfire popping. Now with this one whenever i reléase the gas pedal on 2nd and 3rd gear i am experiencing a pop pop pop sound at the muffler.
this MSA PREMIUM EXHAUST KIT  comes with an Xcelerator Turbo Muffler:
http://www.a-1perfor...rator_mufflers/
This is the one i had before:
http://www.thezstore...ring02a/15-6031
Now do this additional information can help solve the puzzle? Will adding a resonator or glasspack in the middle cancel the deceleration popping at the exhaust?
The popping is due to camshaft duration and overlap, you now have an exhaust system larger, that has less back pressure, thus allowing unburnt fuel to pas through the slightly open exhaust valves.
With back pressure, the unburnt fuel was more kept in the cylinders.
Little bit richer, on mixtures, back timing to 14 or 12 btdc, then check plug colours and run a range or two different, to decrease the plug fouling.
BTW, we visited your country last year, then a run through the Canal. Also Costa Rica, Nicaragua, great beaches, best barbeques, and amazing wildlife! Just regular tourists!
