Patching Engine Bay Holes
2 replies to this topic
#1 260DET
260DET
  • 2,274 posts
  • Tagline:Tribal Elder
Posted 19 May 2017 - 02:54 PM
Anything up to 5 mm is OK, A dab of Selleys Liquid Nails does the job. Big holes warrant a weld over patch but what about the in between sizes? I'm thinking of making aluminium patches to be glued over the holes but there must be a better tidier way.
#2 Brabham
Brabham
  • Donating Members
  • 1,049 posts
Posted 20 May 2017 - 03:41 PM
I'd probably weld anything up to about 10mm and make a patch for anything above that. You should be able to butt weld the patches in and grind down the welds so you can never tell there was a hole there.
#3 gilltech
gilltech
  • Donating Members
  • 1,171 posts
Posted 20 May 2017 - 06:55 PM
Wouldn't one just go to Clarke Rubber & buy a bunch of rubber blind (ie. no hole) grommets?
Then it's easily reversible.
Edited by gilltech, 20 May 2017 - 06:57 PM.
