L Series 5 Speed
15 replies to this topic
#1 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 11 May 2017 - 08:16 AM
I have for sale one 280Z or early ZX north american 5 speed.. Don't know what that means but Jamo ( Grant ) went to a lot of effort to get this box for his turbo engine set as the ratios are better?
Jamo put new bearings and seals through the gearbox when he got it and drove about 10k with it in the car.
I purchased the gearbox in a package with the engine.
I'm taking the engine a little further then Grant so there is no point bolting this really good condition b box behind it and shattering it.
If you want to see a picture that's fine but its a oil free clean and dry gearbox. I have wire wheeled the whole gearbox so its a little bit shiny and very clean and the inside of the bell housing is painted red.. Cause red is faster.
From looking around I think these are the ratios..
* 1st: 3.062
* 2nd: 1.858
* 3rd: 1.308
* 4th: 1
* 5th early 0.773
Chasing $800.00
Cheers Doug
oh for thee too too for too nein five sux
Edited by 44014, 06 June 2017 - 10:19 AM.
#2 dat2kman
dat2kman
  • 4,031 posts
Posted 11 May 2017 - 09:19 AM
Easy enough to pull the bell and ext off, and do an accurate tooth count, to confirm!
Some variants of the 280ZX did come with those ratios,
but other variants, had the truck/ute ratio gearboxes fitted, ie first gear is 3.52
They also had various diff ratios fitted to better utilise such variances in gear ratio sets.
This box above, if its 3.06 first gear, is almost as good as the desired 260Z 2.9 ratio box, save for the laggy fifth gear, but thats very easily swapped for a more spirited .832 regular fifth gear!
#3 44014
44014
  • 817 posts
Posted 11 May 2017 - 10:37 AM
If that's the case... ill do a tooth count on the weekend and put the price up a $1000  >:D
#4 Groundhog
Groundhog
  • 202 posts
Posted 11 May 2017 - 11:36 AM
Can you not count the revolutions of input and output shafts in the various gears instead of having to dismantle it?
Put a cardboard disc on both shafts with a mark,
Put it in the gear you want to check,
Turn the input shaft 10 full revolutions and count the output revolutions?
Edited by Groundhog, 11 May 2017 - 11:36 AM.
  • nizm0zed and 44014 like this
#5 gilltech
gilltech
  • Donating Members
  • 1,077 posts
Posted 11 May 2017 - 12:28 PM
So Jason, what would the ratios in my early-74 260Z 2-seater gearbox most likely be?
Car was NZ-new so general world RHD issue it's been said, not Aus or US-new, might make a difference.
Am interested in having a spare gearbox, one either matching or very close.
Edited by gilltech, 11 May 2017 - 08:01 PM.
#6 44014
44014
  • 817 posts
Posted 11 May 2017 - 01:02 PM
That's what I was going to do. Wasn't planning on splitting a sealed box.
  • Groundhog likes this
#7 dat2kman
dat2kman
  • 4,031 posts
Posted 11 May 2017 - 11:37 PM
Let me get out the crystal ball!!!
No idea, until you count tit. Who knows what may or may not have been swapped over the years!
PITA with box in car, but, jack it up, remove all spark plugs, set front pulley on tdc, put it into gear, climb under, mark the tailshaft with a white dot, attach a pointer stick to a nearby bolt, position tip of pointer at the dot.
Hop up, ratchet socket on crank pulley, rotate It three full turns
Climb back under. Check the white dot relative to the pointer, ifs its just close, its a 2.9 first gear.
( 3 turns of the crank is close enough to 2.9)
If the dot is further away, its a 3.32 ratio first gear
Doug the two shafts method is good, make sure whatever telltale stick etc on output, doesnt move, use a dab of superglue and a bit of plastic stick, for input shaft, use an old clutch plate, mark it to a return reference point.
If you select first, rotate input 2.9/3.0 times, output will do one rev back to start, shes a 2.9!
#8 gilltech
gilltech
  • Donating Members
  • 1,077 posts
Posted 12 May 2017 - 06:09 PM
It's the original gearbox, only been out twice in my 33yrs for clutch renewal.
Car's already on axle stands so a good time to measure using your method, cheers.
Edited by gilltech, 12 May 2017 - 06:10 PM.
#9 HKSZ
HKSZ
  • 251 posts
Posted 12 May 2017 - 07:42 PM
The tell tale for a 2.9 zed box is an oil filler on the drivers side.....most of the time anyway.
#10 theremm
theremm
  • 392 posts
Posted 12 May 2017 - 09:55 PM
Jason's method with the white dot works a treat - did this with mine and very easy to confirm the 2.9 ratio
#11 dat2kman
dat2kman
  • 4,031 posts
Posted 13 May 2017 - 09:37 AM
Unless swapped over.
Have seen a few with filler on RHS, get all excited, only to find standard, or ute/truck ratios, inside!
#12 44014
44014
  • 817 posts
Posted 13 May 2017 - 02:50 PM
Put some zip ties around the bit of the driveshaft I use to stop the oil coming out and the input shaft.
Can confirm 3.06 1st......turns about 10 degrees past 3 turns for one revolution of tail shaft.
Price amended
#13 gilltech
gilltech
  • Donating Members
  • 1,077 posts
Posted 13 May 2017 - 03:46 PM
OK, so if you're wanting $1600 for a 3.06, then what do you reckon a 2.9 is worth?
#14 dat2kman
dat2kman
  • 4,031 posts
Posted 13 May 2017 - 04:03 PM
$1600 for a 2.9 unit, fully rekitted, with all reciepts, is a good price.
These have the 0.83 fifth gear, desireable!
Same sold recently for $1800 a couple months back.
#15 44014
44014
  • 817 posts
Posted 06 June 2017 - 10:19 AM
Bump, Price reduction :)
#16 44014
44014
  • 817 posts
Posted 26 June 2017 - 07:51 AM
Sold
