Weber Idle Jets
3 replies to this topic
#1 Mike260LW
Mike260LW
  • 126 posts
Posted 01 April 2017 - 02:50 PM
OK all you Weber gurus, on stripping down our DCOE 48s to re- kit them, we found the idle jet air drill ("f") holes have been filled in. Any ideas on why this would be? Is this a performance thing or a quick-fix by some one. Obviously the kit replacement ones are drilled as per spec. Not sure what will result if we put the new ones in. Your thoughts please.
#2 260DET
260DET
  • 2,201 posts
  • Tagline:Tribal Elder
Posted 01 April 2017 - 09:14 PM
Sure that some weight saving maniac has not got at them?
#3 dat2kman
dat2kman
  • 4,053 posts
Posted 01 April 2017 - 11:54 PM
Slide some jet drill shanks into them, see if they have been redrilled.
If side air hole has been filled, the previous tuner may have just relied on the first stage progression tube for air to bypass the closed butterfly, sometimes done with high breathing engines.
#4 Mike260LW
Mike260LW
  • 126 posts
Posted 03 April 2017 - 07:37 PM
Thanks Jason. After much deliberation we have decided to revert to 45s to try and pickup some bottom end for Tarmac rallys. Our original set of 45s are pretty sweet but we rekitted the 48s with the replacement idle jets and we will worry about tuning if we ever peruse this path again.
