Location For Hazard Switch '71
3 replies to this topic
#1 aircobra
aircobra
  • 742 posts
Posted 12 March 2017 - 10:37 PM
search of the 'net shows that there should be a toggle switch in the midde of the dash. but my holes are all blanked out? was it not standard in AUS cars?
#2 GongZ
GongZ
  • 893 posts
  • Tagline:Watanabe wannabe
Posted 12 March 2017 - 11:04 PM
Hazard light switches were not fitted to Australian market 240Z's of any year.
See this topic;
http://www.viczcar.c...-hazard-switch/
From post #31;
"So, in summary, all you need to do to add hazard lights to an Australian 1973 240Z is;
- Obtain a US hazard switch
- Remove the loop-back connector from the 6 pin connector and plug in the US switch
- Install a 12V flasher unit to the previously unused L-shaped two pin (one green and one white wire) connector near the blinker flasher unit.
I would imagine that the same would apply to earlier 240Z's, using the appropriate vintage US hazard switch. They may even be interchangeable, because the 6-pin connector looks identical - just check the wiring diagram for your model."
Edited by GongZ, 12 March 2017 - 11:12 PM.
#3 gav240z
gav240z
    Administrator
  • 12,974 posts
Posted 12 March 2017 - 11:33 PM
Do you even search bro? I find you often start threads on topics that have been covered in detail before.
  • PB260Z, andyk_79 and Andrew_L26 like this
#4 aircobra
aircobra
  • 742 posts
Posted 15 March 2017 - 09:45 AM
thanks gongz. off to ebay for the switch.
