How To Put Back The Hood Torsion Bars? Despareate And Hingeless
20 replies to this topic
#21 KatoKid
  • 1,735 posts
Posted 20 May 2017 - 05:45 PM
Did this today...piece of cake.
  1. Mount one hinge with 3 bolts, mount the other side with just the lower front bolt so it can swivel downwards and back.
  2. Place the tension rod with the T head on the side with 3 bolts and slide the other 90 degree end into the other side, it will be easy because this side is rotated down to relieve tension.
  3. Rotate the hinge and install the other 2 bolts.
  4. Install the 90 degree end in the originally full bolted hinge and then twist the other with the T head until it can fit into the hole in the hinge. It will require some force bit its pretty easy.
