Thoughts On A/c Yes Or No?
11 replies to this topic
#1 600Z
600Z
  • 265 posts
Posted 16 January 2017 - 10:20 AM
Hi guys,
Just after some thoughts on whether or not to put A/C into a 260Z which didn't come out with it?
I can get most of the parts pretty cheap that's all.
Justin
#2 daretobedifferent
daretobedifferent
  • 117 posts
Posted 16 January 2017 - 10:52 AM
It'll obviously add to the weight, but if its a street driven zed then I think A/C is a must.
I used to daily drive an mx5 without A/C (for 5yrs straight), and while it was a fun car to drive, I hated driving it on those 35+ DegC days.
  • gav240z and 600Z like this
#3 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 16 January 2017 - 11:21 AM
Hi
I have re commissioned the A/C in my for a couple reasons.
- on hot days it is no fun in traffic.
- on wet days my demister isn't the best A/C overcomes that.
- The car came with it and it seemed crazy to have it all sitting there and no benefit.
PB
  • 600Z likes this
#4 Groundhog
Groundhog
  • 210 posts
Posted 16 January 2017 - 12:36 PM
Harmonic balancer pulley with A/C drive are getting hard to replace.
Z Car store no longer have stock and could not get one locally.
If you have this twin row balancer you'll be fine, other wise make sure you get it with the conversion gear.
You can use another harmonic balancer and add an A/C pulley which is a bit of messing around.
Mine has 13 mm fan belt for the water pump, and 16 mm vee belt for the A/C compressor.
#5 600Z
600Z
  • 265 posts
Posted 16 January 2017 - 01:34 PM
Thanks guys for your replies and I do agree, I have it in the orange car but not in the light blue one and it's certainly nicer to drive the one with it on the hot days.
Groundhog I do have one that's on another engine I have which I would use but very good point I hadn't really thought about it until you mentioned that lol.
#6 600Z
600Z
  • 265 posts
Posted 16 January 2017 - 05:27 PM
Quick question as I'm not near my car does anyone know if a 260z 75 model has the vacuum or non-vacuum controls?
#7 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 16 January 2017 - 06:09 PM
Hi
My bus is running an L28E out of 280ZX so that motor had multi belt capacity on the balancer.
The balancer on the original L26 also had multi belt capacity due to the car having factory A/C.
My question - would the balancer off the late L26 & L28E suit the earlier single pulley engines fitted in non A/C cars ?
cheers
#8 YosemiteZed
YosemiteZed
  • 100 posts
  • Tagline:Rust never Sleeps
Posted 16 January 2017 - 06:15 PM
Hi
the '75 260z fitted with factory AC had vacuum control
Phil
  • 600Z likes this
#9 600Z
600Z
  • 265 posts
Posted 16 January 2017 - 10:08 PM
Thanks Phil
#10 260DET
260DET
  • 2,223 posts
  • Tagline:Tribal Elder
Posted 17 January 2017 - 07:39 AM
The OP is in Tasmania, maybe a heater would be the first priority. Seriously, does it really get hot enough there to make enough difference?
#11 WhitleyTune
WhitleyTune
    Member
  • PipPip
  • 10 posts
Posted 18 January 2017 - 09:46 AM
Anyone played around with the aftermarket A/C setups you can get these days for hot rods etc? Would be so nice to have electric A/C compressor but I think they really need 48v to work well.
#12 600Z
600Z
  • 265 posts
Posted 18 January 2017 - 02:19 PM
Lol hi Richard,
And the answer is yes it does, my 260 has A/C and I use it a fair bit and not only when it's hot it's good for clearing the screen ;) it's the other way around I don't have the heater hooked up in that one because the rocker cover is pretty close to the outlet so I need to find some nice hoses with a sharp 90deg bend lol.
I know it certainly would be handy but just wondering if it's worth the hassle in doing as is a fair bit of stuffing around by the look of it.
Justin
