Tank Filler Hose, Silicone Ok?
6 replies to this topic
#1 260DET
260DET
  • 2,223 posts
  • Tagline:Tribal Elder
Posted 15 January 2017 - 07:01 PM
Custom fuel cell for the project Z, silicone is available in various diameters, proper fuel hose not so. Am thinking of general purpose silicone hose like is used for radiator and intake hoses.
#2 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 15 January 2017 - 08:40 PM
Hi,
No not a good idea.
To the best of my knowledge petrol will slowly disolve the silicon.
PB
  • Paul_S likes this
#3 Paul_S
Paul_S
    Member
  • PipPip
  • 16 posts
  • Website:http://www.autogadgetz.co.uk
  • Tagline:Yearning for an early Z
Posted 16 January 2017 - 05:40 AM
I agree.  It will be OK for a time but will cause you problems in the long run.
#4 260DET
260DET
  • 2,223 posts
Posted 16 January 2017 - 07:21 AM
Thanks blokes, looks like a trawl through the wreckers will be necessary.
#5 PB260Z
PB260Z
    Peter (PB)
  • 3,281 posts
Posted 16 January 2017 - 10:04 AM
Hi
Rather then spend ages crawling through wrecks looking for the right hose maybe try this, it worked for me on a previous project.
- Grab the longest piece of filler hose (with the correct ID) that you can find.
- Get some appropriately sized stainless exhaust pipe (get it bent to shape)
- A few hose clamps.
- Use the hose at each end and the exhaust pipe in the middle
Just a thought
#6 chartoo
chartoo
  • 362 posts
Posted 16 January 2017 - 04:58 PM
I remember being able to get 2 inch hose from enzed or some industrial places.
Just typed it into google
http://www.dayco.com...2217&P=16027764
Remember it was about $50 a meter
#7 nizm0zed
nizm0zed
  • 1,311 posts
Posted 16 January 2017 - 05:08 PM
our local industrial supplies joint has silicone hose in pretty much any size you needed, We used to use it between the fuel tanks, its rated for diesel and petrol.
Im not sure who would be local to you, but a quick look at google would probably tell you.
Definitely cant use the 'retail' blue or black type of hose normally used on intakes, the silicone breaks down in the fuel and the particles clog up your filter and pump.
http://www.southernhose.com.au/
