Clive Cams 733A
2 replies to this topic
#1 Yamahacam
Yamahacam
  • 73 posts
Posted 25 November 2016 - 08:01 AM
Going to send one of my standard cams down to get done soon. From what I have read this seems to be a good mild profile. Guess the question is, are there any other suggestions? 733A from Clive, is a 72 too much if I am only going to stay with twin su's?
Motor is L26 standard bore with:
Flat top pistons
Has had port work done but not sure as to what extent
HM extractors with 2 1/4 exhaust
240z dome tops
5 speed manual
3.54? diff
Lightened stock flywheel
It isn't a daily, no a/c or power steer.
Not a track car, just want it to sound good and be fun to drive.
I have a few cams I could get done if there are a few good ones to choose from.
Thanks for any advice.
Edited by Yamahacam, 25 November 2016 - 02:26 PM.
#2 dat2kman
dat2kman
  • 4,134 posts
Posted 25 November 2016 - 09:59 AM
That will be fine.
You then might to consder a different dff ratio, to liven it up.
3.9, k, 4.1, better, 4.4, gets a bit RPMy on the highway.
  • gav240z and Yamahacam like this
#3 Mike260LW
Mike260LW
  • 128 posts
Posted 27 November 2016 - 08:44 AM
A 72 works grind would be fine too. Agree with dat2kman a shorter diff ratio will bring it alive.
