Indicator Switch Contact Points - Repair?
4 replies to this topic
#1 PeterAllen
  • 1,356 posts
  • Tagline:Manana!
Posted 20 November 2016 - 11:35 AM
To engage the o/s indicators requires and extra 'tug' on the arm of the switch. I've pulled it apart - but unfortunately didn't take photos - and it appears the contact points are worn. They are similar in appearance to distributor contact points.
I'm wondering if anyone has suggestion how I could either build up the worn/pitted contacts, e.g. silver solder? or modify the mechanism to gain more movement, e.g bigger ball, stretch spring?
(edit) There are some images here of an earlier 4 contact switch but mine is a 2 contact later version.
Edited by PeterAllen, 20 November 2016 - 12:14 PM.
#2 TDoherty
  • 56 posts
Posted 21 November 2016 - 06:37 AM
I have the same problem and used this link as the basis for pulling mine down and cleaning/refurbishing it however it really didn't result in a marked improvement of any sort!
I'm about to pull it out/down once more to see what else I might be able to do so will follow this string to see if anyone else can offer any pearls of wisdom.
Cheers Tony
#3 260DET
  • 2,346 posts
  • Tagline:Tribal Elder
Posted 21 November 2016 - 08:10 AM
The only thing that I can think of is to hard solder on some new points from, say, ignition points. Or else use a brazing or more suitable rod to build the old ones up. Perhaps someone with suitable expertise can offer a repair service, there is sure to be a way to do it.
#4 PeterAllen
  • 1,356 posts
  • Tagline:Manana!
Posted 21 November 2016 - 08:38 AM
I asked the same question on a couple of sites and got this handy solution.
It may not suit the purist but I've already changed a few things on my S30 so I don't think this should influence it's provenance too much.
Google the part number (Dorman part #85905) to get a good idea of the item
Also, I suggested in the OP that a 2 terminal switch was a later version, I now think I got that the wrong way around and it's the earlier approach.
Tony. Thanks for the link. Unfortunately the contacts on mine are simply worn/sparked away rather than dirty. I really needed to either build up the contacts or get more movement of the mechanism.
Edited by PeterAllen, 21 November 2016 - 08:45 AM.
  • TDoherty likes this
#5 Gyzmo
  • PipPip
  • 20 posts
  • Tagline:Bespoke
Posted 30 November 2016 - 07:32 PM
WRT the contacts I soft soldered mine...
There is a guy in the US that rebuilds both the Turn Signal & Light Switches.
I broke the horn contact mount in my Z when removing the steering column cowel - due to it's age - plastic is very brittle.
He 3D prints the mounting block for US$5 + US$10 delivery - pay via Paypal
I've posted an image of the broken bit in the gallery...
