L26 Camshaft Id?
5 replies to this topic
#1 Yamahacam
Yamahacam
  • 52 posts
Posted 22 October 2016 - 01:08 PM
Came out of an L26, anyone have any ideas on profile? Is CE the old Camshaft Engineering from Brisbane? Thanks for any help.
#2 dat2kman
dat2kman
  • 4,031 posts
Posted 22 October 2016 - 04:25 PM
Got any other numbers on it?
Nissan markings? ( could be a billet!)
#3 Groundhog
Groundhog
  • 202 posts
Posted 22 October 2016 - 08:37 PM
This posting might give you some leads also.
http://www.gmh-toran...ft-engineering/
#4 Yamahacam
Yamahacam
  • 52 posts
Posted 24 October 2016 - 06:32 AM
Thanks Groundhog, I have already tried all of those people with no answers. Was running in an engine I have so will probably just run it and see what it does. Don't have the engine close Jason but from memory it was a Nissan cam.
#5 dat2kman
dat2kman
  • 4,031 posts
Posted 24 October 2016 - 06:12 PM
If that one you have, has had a bit of a rework, it may be an idea to run it up on a dummy assembled engine, just needs no 1 piston fitted, and chamber no 1 valves fitted, a degree wheel, and check its opn/closing angles at 50 though valve lift, and total lift.
OR, send it off to a shop that has a cam profiling machine, to let you know what it is.
Save ruining something, if its already good, with a fresh re-grind!
Use a known stock cam, they can easily take a 68 to 72 deg type re-grind, and depending on how much valve seats have been sunk in, slightly thicker lash pads will have it setup nicely.
#6 Yamahacam
Yamahacam
  • 52 posts
Posted 25 October 2016 - 08:31 PM
Thanks Jason, might find someone to profile if just in case I ever want to sell it.
