240Z Rear Wheel Cylinders Failing Consistently!
brakes wheel cylinders
21 replies to this topic
#21 dat2kman
dat2kman
  • 4,146 posts
Posted 30 September 2016 - 10:10 PM
Standard, factory fitted.
Rules allw holes for cooling, on rears.
To keep up the front, you will boil fluid, turn pads into apple crumble, and warp discs.
Add in there, severe radial micro cracks, and cracks to drum linings.
Treat them as consumables.
Funnily enough, when running in Sprints etc, against the massive bg braked 4 wheel dsced Z's runnng triples, bg mtrs etc,
The Group S repped Z's are as quick, if not quicker.
That is satsfying.
#22 Nickymac
Nickymac
    Newbie
  • Pip
  • 7 posts
Posted 03 October 2016 - 03:04 PM
That is satsfying.
That's the difference between a car that weighs close to a ton versus 670Kg! None of that happens, the pads and linings last a few seasons, and the drums have been on the car for many many years, it doesn't boil fluid, nor warp rotors. It does however leak fluid from the rear cylinders....
Also tagged with one or more of these keywords: brakes, wheel cylinders
