L28Et Engine Package - Canberra, Act
L28 L28ET Autronic GT35R Turbo EFI
20 replies to this topic
#1 6cylpwr
6cylpwr
    Newbie
  • Pip
  • 7 posts
Posted 07 September 2016 - 06:03 PM
Hi All,
For sale is the engine package that came in my somewhat recently acquired 240z.
Some of you may be familiar with the car and/or it's old owner.
The engine is not in running condition, I have never seen it run, nor have I investigated the damage myself.
Much of this information has been taken from the vehicles sale thread.
The engine has been sitting for 10+ years. I bore scoped it upon removal and found no signs of corrosion in the the bores.
It has been sitting with the manifolds detached for a few months now, so I will re-inspect when prompted by prospective buyers, and attempt to provide evidence (assuming I can take a good photo of the bore scope screen)
All items located Belconnen Region, Canberra, ACT.
L28:  $350 - SOLD
The BAD: Supposedly has damaged big end and main bearings due to loss of oil pressure, in which case I would assume the crank is also damaged. Apparently also has an L20B oil pump fitted.
The GOOD:
F54 Block, P90 Head
Compression: 7.4:1 suggests factory turbo bottom end. Nissan cam cover.
Cam: Crow #58643 Intake: 212 deg 0.075" dur, 0.480" lift, Exhaust: 210 deg 0.075" dur, 0.495" lift
Standard piston, rods, crank.
Balancer: Custom Chris Wood built using BMW Inline 6 balancer.
EFI: SOLD  Pics can be found here: https://drive.google...mJuMlM4MDV1d2c along with a short video showing the ecu is working
Autronic SMC v1.99-2 ECU (supposedly tuned to 19psi with the GT35R listed below)
460cc N/A S5 RX7 injectors - SOLD
Bosch adjustable rising rate fuel pressure reg
Scorcher custom hall-effect distributor
Bosch 716HEC ignition coil
Bosch ignition module
Standard 280zx EFI intake manifold with XF Falcon throttle body and adaptor SOLD
Engine wiring harness
Hot Stuff:  $1000 - SOLD
Garrett GT35R turbo with 0.82 rear housing. Braided Oil, water and boost control lines.
Boost control solenoid with fittings
Huge Airfilter
ARE 520x300x90 bar and plate intercooler with 2.5inch Stainless piping and silicones
Custom Ian Rowlerson exhaust manifold. stainless, tigged, tuned length, split pulse collector, external wastegate flange
Sub-zero 55mm wastegate with 2.5" screamer pipe
Sump with turbo drain and oil temperature sensor bung
3" mandrel bent mild steel exhaust to the diff, take as much or as little of this as you like. New dump pipe flanges are easily available, I can also provide one if needed.
I can aid in transport to a freight depot, or to a local buyer if you are unable to pickup.
Old owners car sale thread for further reference: http://www.viczcar.c...35r-conversion/
UPDATE:
I've made some discoveries today. Looks like there was a build up of corrosion material/debris? in the cooling system, but I could not see any damage in the block or water pump. I have included pictures of this (including a picture of the bore scope aimed at the water pump impeller.
I also found a small amount of rust in 2 of the cylinders that sat with a valve open in each. This has likely happened due to me removing the manifolds and as such appears recent, so I suspect it has not pitted the bores yet. And what appears to be a very small amount of oil in one of the cylinders. I was also able to turn the engine over by hand just by the balancer (no tools).
On the upside to all this, the intake ports appear to have been touched up. I could see no evidence of such work on the exhaust ports.
Pics of Hot Stuff can be found here:
https://drive.google...X1U&usp=sharing
Pics of the L28 including aforementioned bore scope images can be found here: https://drive.google...FE&usp=sharing
Edited by 6cylpwr, 25 May 2017 - 09:23 PM.
  • Clarky93 likes this
#2 gav240z
gav240z
    Administrator
  • 12,394 posts
Posted 07 September 2016 - 06:15 PM
Are you willing to separate head and block? OR want it gone in 1 package?
#3 6cylpwr
6cylpwr
    Newbie
  • Pip
  • 7 posts
Posted 07 September 2016 - 06:18 PM
I would prefer it gone in one package, but I will separate them if there is a buyer for the other as well.
EDIT: sorry GAV, I re-read your post and realised you did not specify which you were after
Edited by 6cylpwr, 07 September 2016 - 06:24 PM.
#4 240z71
240z71
  • 170 posts
Posted 07 September 2016 - 06:20 PM
Ill jump second in line behind Gav for the l28 thanks.
#5 gav240z
gav240z
    Administrator
  • 12,394 posts
Posted 07 September 2016 - 06:22 PM
If you want the entire short block go for it, I only want the P90 head myself. But have no immediate method of collecting it from the ACT.
  • zed73 likes this
#6 chris240
chris240
  • 2,187 posts
Posted 07 September 2016 - 07:40 PM
I will take the L28..
Call or text me on 0408770100
#7 chris240
chris240
  • 2,187 posts
Posted 07 September 2016 - 07:50 PM
Edit....I can purchase, acquire, buy , take , steal the l28 as a complete unit.
#8 240z71
240z71
  • 170 posts
Posted 07 September 2016 - 07:52 PM
Sorry chris but im next in line for the l28 long block. Waiting for a reply off 6cylpwr
#9 Clarky93
Clarky93
  • 53 posts
Posted 07 September 2016 - 08:51 PM
Pmed
#10 44014
44014
  • 817 posts
  • Tagline:Garage San Maru
Posted 08 September 2016 - 08:21 AM
Pm'd
#11 44014
44014
  • 817 posts
Posted 08 September 2016 - 08:24 AM
I will take the turbo cam from the head who ever buys it.
#12 dat2kman
dat2kman
  • 4,031 posts
Posted 08 September 2016 - 01:28 PM
If the eventual long mtor purchaser dscovers that the crank s too far gone, I have good unmolested used L28 crank
$120 plus freight.
#13 6cylpwr
6cylpwr
    Newbie
  • Pip
  • 7 posts
Posted 08 September 2016 - 06:31 PM
All PMs have been replied to.
1st post has been updated with new information and links to images.
#14 Triptych
Triptych
  • 348 posts
  • Tagline:77 GS30
Posted 10 September 2016 - 03:53 PM
Man shame to see you decided to split this all up but good to see you finally worked out a price for it all. I was interested in buying the complete package a couple months back but you never got back to me.
#15 Scotty_Rah
Scotty_Rah
  • 148 posts
  • Tagline:260Z | RS30-010069 Resto-mod
Posted 12 September 2016 - 09:54 PM
Has the L28 sold or still up for grabs?
#16 6cylpwr
6cylpwr
    Newbie
  • Pip
  • 7 posts
Posted 12 September 2016 - 09:59 PM
L28 and Hot Stuff are both sold pending payment.
#17 chris240
chris240
  • 2,187 posts
Posted 13 September 2016 - 09:42 PM
5 minutes around the corner and no cigar.
Shite happens..
#18 6cylpwr
6cylpwr
    Newbie
  • Pip
  • 7 posts
Posted 15 October 2016 - 03:58 PM
Bump.
Minimal interest in the EFI setup, suspect this is due to Datsun era owners being afraid of anything more complex than lightbulbs and starter motors.
I'm opening up to parting out what remains. Already have a party chasing everything connected to the intake manifold.
Are there any interested parties for the ECU with complete ignition setup?
#19 andyk_79
andyk_79
  • 612 posts
Posted 17 October 2016 - 01:20 PM
Can I make a friendly suggestion that insulting Datsun owners on a forum used by a community of Datsun owners is not going to increase your chances of a sale ?
#20 6cylpwr
6cylpwr
    Newbie
  • Pip
  • 7 posts
Posted 17 October 2016 - 01:51 PM
It was a joke...
Thanks for the bump friend
Edited by 6cylpwr, 17 October 2016 - 01:52 PM.
Also tagged with one or more of these keywords: L28, L28ET, Autronic, GT35R, Turbo, EFI
