240Z / 260Z Plastic Window Winder Regulator Rollers
8 replies to this topic
#1 CraigZ
CraigZ
  • 167 posts
Posted 02 September 2016 - 12:05 PM
Does any one need to replace  240z / 260z plastic window winder regulator rollers?
if so let me know , i recently turned up some of these for someone as replacements aren't  available .
$25 each, $45 a pair and $65 for 3 , posted australia wide ,
any questions please let me know
pictures contain and old one and the pin which aren't included , you get like the 2 bright white ones.
Thanks
Craig
Edited by CraigZ, 02 September 2016 - 12:11 PM.
  • gav240z and Scotty_Rah like this
#2 CraigZ
CraigZ
  • 167 posts
Posted 21 December 2016 - 03:16 PM
Hi all,
Just thought i would post up some pictures of a winder mechanism that received 2 new rollers, 2 new bushes and 2 new pins welded in.
If any one needs one repaired just let me know , some rough pricing in previous post and  extra pins or large plastic washers add $10 each to roller pricing.
Thanks
#3 Scotty_Rah
Scotty_Rah
  • 152 posts
  • Tagline:260Z | RS30-010069 Resto-mod
Posted 22 December 2016 - 08:39 PM
looks great Craig! looking forward to getting it back and installing it :)
  • CraigZ likes this
#4 gav240z
gav240z
    Administrator
  • 12,651 posts
Posted 23 December 2016 - 08:43 AM
Awesome, great to know this is a possibility.
  • CraigZ likes this
#5 d3c0y
d3c0y
  • 2,908 posts
  • Tagline:Forum Jerk
Posted 23 December 2016 - 09:15 AM
Hi Craig, I currently have the window regs out of my doors and i'm thinking that it would be prudent to do this while it's all apart, as i had loose rattley windows that were hard to wind up.
So you need 3 per side right? Do all three usually need replacing and do you have to weld the new pins to the reg arms right?
#6 CraigZ
CraigZ
  • 167 posts
Posted 25 December 2016 - 09:38 PM
Hi,
Thanks for your interest!
Are your 3 rollers and larger plastic collars still intact and appear undamaged? and yes there are 3 per mechanism and would need to be welded in if replaced.
If yours all appear to be fine i am not sure that replacing with new would be necessary. if your window was a bit stiff it may be because of other issues.
- window felts worn out creating slop/play int the window allowing it to kick over slightly and wind up unevenly.
- there is also another guide roller in the top of the door which you can buy new from the US.
- the mechanism may also need general cleaning and greasing.
- inside door window guides out of position...
what does your mechanism look like currently?
here is a post from NZ it has the another roller in one of the pics
https://zclub.nz/vie...f2d1796f2e5ee19
Cheers,
Craig
#7 CraigZ
CraigZ
  • 167 posts
Posted 25 December 2016 - 09:41 PM
https://zcardepot.co...-260z-280z.html
the other roller in the top of the door
#8 CraigZ
CraigZ
  • 167 posts
Posted 02 July 2017 - 08:16 PM
Hi guys ,
Just BUMPing this one as i am doing a turn up on the lathe of these this week so if anyone is interested , $5 off the above prices which will be standard price from now on
Thanks
#9 gilltech
gilltech
  • Donating Members
  • 1,147 posts
Posted 02 July 2017 - 08:46 PM
That NZ post talks about sourcing rollers at Bunnings. Certainly they have a range of replacement rollers for sliding windows, doors, screens etc. I sourced some there for my Mustang - Rolltrak was the brand IIRC.
What would be useful are replacement rivet-on retainers.
