Tacho (Not Idle) Fluctuating
2 replies to this topic
#1 adam
adam
  • 219 posts
  • Website:http://twofortyzee.wordpress.com/
Posted 07 August 2016 - 08:22 PM
Gday all,
Hope you guys could give me an idea into what could be happening.
Bit if background, I have a '73 240z running an L28 with a 280zx electronic distributor, MSD 6A ignition, stock tacho with MSD tacho adaptor/booster.
My issue is the tacho fluctuates with every indicator flash, drops dramatically when the headlights are on (relays installed) or if my heater blower is on.
Note, driving/revving does not change, purely a tacho reading issue.
I have just bought a new battery and had a 280zx internally regulated alternator installed about two years ago.
Any ideas what is causing this fluctuation? It's bloody annoying!
Cheers,
Adam
#2 WA240Z
WA240Z
  • 204 posts
Posted 08 August 2016 - 03:14 PM
Hi Adam,
One thought is the tacho is quite sensitive to fluctuating supply voltage, given you have covered a lot of bases with the (+) positive side of the supply, I would be checking the quality of your (-) ground connections. Try taking the negative supply to the tacho direct with a new wire to a nice clean ground point. Poor ground connections unfortunately dont raise there ugly head until there is load on the circuit making tracing a real pain in the neck. Hope this helps, and good luck.
Billy
#3 adam
adam
  • 219 posts
Posted 09 August 2016 - 09:51 PM
That was my next step Billy, cheers.
I am all ears for any other suggestions.
