What Happened To This Paint?
2 replies to this topic
#1 neRok
  • 230 posts
Posted 26 July 2016 - 04:11 PM
I've just painted the radiator support area, and got an area that is 'spotty'/grainy. Just thought I would get the opinion of some pro's as to why this happened? It is the same on both sides. I went back to bare metal, etched, surface+high-build primed, then put on the black. No sanding in between (I don't think this area is that important). My guess is it is overspray from high-build that built up after spraying the vertical surface that is parallel with the radiator.
#2 gilltech
  • Donating Members
  • 1,279 posts
Posted 26 July 2016 - 07:26 PM
I think you're right, and it's overspray that's gone on half dry. Buff it back?
#3 Retro Z
Retro Z
  • 1,421 posts
Posted 26 July 2016 - 08:37 PM
Yeah its either overspray or severe solvent-pop by laying on too many layers too fast without letting it flash off in between coats. Most likely just sprayed on dry (overspray)
