Re Ba Falcon Fuel Injector Suitability For 260Z.
3 replies to this topic
#1 zeds4ever
zeds4ever
  • 857 posts
  • Tagline:Old Member
Posted 05 July 2016 - 11:28 AM
  About to make another pilgrimage to Picknpayless (Blacktown) shortly to seek & find .Read a post where a member used BA Falcon ? fuel injectors in his 280ZX motor. Contemplating doing the same set up if I can locate a decent set at the above location.
Just wondering what is the real benefit of these over my older type 280ZX units & should I bother with changing existing set up .
                                                      Regards : Alan .
#2 PB260Z
PB260Z
    Peter (PB)
  • 3,237 posts
Posted 05 July 2016 - 08:33 PM
Hi Alan
The BA injectors will have a much greater flow rate than the L28E ones.
I would be concerned about running rich if you increase the injector flow by too much - I am assuming you are running the standard (non adjustable) ECU.
PB
#3 zeds4ever
zeds4ever
  • 857 posts
Posted 05 July 2016 - 08:58 PM
                                  Message understood Peter , so will be satisfied with what I have .
                                                         Regards : Alan .
#4 dat2kman
dat2kman
  • 4,029 posts
Posted 05 July 2016 - 10:04 PM
L28E injectors flow 188cc
L28ET injectors flow 212cc
VL Commdore RB30E injectors flw 212cc
By "clipping" the dropping resitors you can back off the duty cycle on the 212cc njectors. And for higher demand- Air/fuel rates, using a variable potentiometer, increase duty cycles, without maxing out injectors.
Max out stock L28E njectors and they get spluttery and cant handle it.
The research ito this, and L28 E intake manifolds was done over a few years and cost in excss of $5000?
I am thinking of selling this research, including all hardware, notes, flow charts, flowed intakes, mandrels to manufacture larger throttle plates, bosses to mount throttle bodies onto a lathe, for boring out,,the flows for the various throttle bodies available, and the larger TB's, modified AFM's. $2000 for over $5000 cost, seems quite fair!
