Timing Chain Crank Sprocket Removal?
2 replies to this topic
#1 manya3084
  • 53 posts
Posted 28 June 2016 - 10:17 AM
Hi all,
Getting ready for an upgrade in the next few weeks (Pictures will come once i lock in a weekend at my mates house) . Just a question so I don't get stumped during the process.
As I have a new timing chain kit with new guides, cam, and crank sprockets, I cannot seem to get a clear picture from the haynes and even the FSM.
Will the crank sprocket for the timing chain simply slide off once the crank pulley is removed? or will it require a little more persuasion, ie, heat.
The rest seems pretty simple. At least with the megasquirt I don't realy need to line up the distriburator at TDC. I can just install it anyway I like and set its Zero position with a timing light.
#2 1600dave
  • 643 posts
Posted 28 June 2016 - 11:33 AM
Slides off, it just uses a key to position it.
#3 Linton
  • 533 posts
  • Tagline:1976 260z 2+2 Sunburst 1989 300zx Z32TT 2+2 Black
Posted 28 June 2016 - 11:34 AM
mine simply slid off by hand, there are posts where chaps have used pullers chisels and heat, luck of the draw I'm afraid ..
Edited by Linton, 28 June 2016 - 11:35 AM.
