Diggers Bunings Stripper - Is There Any Better Options
5 replies to this topic
#1 aircobra
aircobra
  • 691 posts
Posted 27 June 2016 - 05:39 PM
have started to do a bit of stripping on the front guards and am finding that diggers gel only does an average job, even with 3 mm thick layer and plastic over the top
should i wait for a bit longer?
it starts to wrinkle within 10 min and then seems to stop
based on good methylene chloride, it should be plenty powerful
has anyone tried other brands eg the supercheap one ?
#2 daretobedifferent
daretobedifferent
  • 117 posts
Posted 27 June 2016 - 06:48 PM
I've tried the Septone one from Supercheap and that works well. Let it sit for awhile and you'll be happy with the results.
Unfortunately the Diggers branded paint stripper really does suck.
  • AndBir likes this
#3 Lightmaster240z
Lightmaster240z
  • 1,609 posts
Posted 27 June 2016 - 07:18 PM
I was told to cover it with a plastic bag to make it work better
#4 aircobra
aircobra
  • 691 posts
Posted 27 June 2016 - 07:35 PM
yep done that. stops it from drying for sure
#5 CBR Jeff
CBR Jeff
  • 971 posts
  • Tagline:Often lost
Posted 27 June 2016 - 08:29 PM
Septone and glad wrap worked for me.
You need some warmth to help the chemical reaction take place. Probably about 20 deg. But less than 30 deg
Jeff
  • AndBir likes this
#6 Retro Z
Retro Z
  • 1,404 posts
Posted 27 June 2016 - 08:38 PM
Use some course sandpaper and scuff up the surface before applying the paint stripper, cover with plastic for an hour and then use a razor blade scraper with the long handle, then use a water compressor to clean off the left over residue.
