Turbo Manifold And Cam Identification Help
L28 Turbo P90 Cam Manifold
4 replies to this topic
#1 Triptych
Triptych
  • 352 posts
  • Tagline:77 GS30
Posted 09 June 2016 - 07:46 PM
Hey guys,
I have been trying to sort out my parts for my build and as I have collected a lot of stuff over the years I am having some trouble identifying a couple of things.
Firstly is this turbo manifold. It was with my L28 when I purchased it (not on the engine) and I did a rough mock up to see if it would fit today but seems to be a few mm short on the end lugs (I am pretty sure middle ones line up just either end) and I did notice a lot of the US manifolds are actually sliced right through the last holes on either side giving side to side movement where as this is just a hole for the stud. When I purchased my engine it was a bunch of parts already torn down and such and a lot of spares as well.
th_5CE03148-FC76-4B35-ADAD-7328450B2D07.th_19D58331-5C3A-4358-B23E-1322EB7CD357.th_D7108DC1-F98E-4054-B0B5-AEB8C72DC47C.
Secondly is this cam. Now I have seen in USA that turbo cams in the p90 are similar with holes drilled throughout the cam with no spray bar but there is a spray bar attached to this one as well. It was also located in a box with all my engine parts. Basically also need to know if its safe to run without the spray bar.
th_690F350D-9D8F-4C31-949D-37D8668E714D.th_3793CCF1-ECD7-4A09-BB37-CFBE7A5C07F1.th_52BAC0E8-C80E-446C-B496-13200B438B44.th_3C6082D3-0107-40BD-A801-88C1E7E140CB.
Basically I will be updating my sale post with a few more items for todays clean up but need to know if I can make this turbo manifold and cam work for my L28 turbo build (P90/F54).
Thank you for any help you can provide.
#2 pauly_adams
pauly_adams
  • 1,160 posts
Posted 09 June 2016 - 08:08 PM
the turbo manifold is a L20ET small port manifold, the cam is a stock L28E A grind camshaft.
#3 dat2kman
dat2kman
  • 4,085 posts
Posted 09 June 2016 - 08:25 PM
I have a spare P90 Turbo cam, if you are after one!
Check the height/widths of the port entries into that manifold, i have a stock cast iron L28E mani that came off a P90, i can measure for you.
The L20ET turbo heads do have slightly smaller exhaust ports, compared to a P90 exhaust ports.
If it is, you could always match the ports to a int/exh gasket
( yes, Got a decent die grinder here, can do that foryou,,,)
#4 Triptych
Triptych
  • 352 posts
  • Tagline:77 GS30
Posted 09 June 2016 - 09:31 PM
Cheers for that Jason. I have sent you a PM. Is it right for me to be having the issues with the turbo manifold not seeming to fit with the exhaust studs (the hole in the manifold seem a few mm short so would need enlongating)?
#5 Triptych
Triptych
  • 352 posts
  • Tagline:77 GS30
Posted 09 June 2016 - 09:33 PM
Also forgot to say thanks as well Pauly for the information. Hopefully with some help from Jason I can get this manifold to work and will have the stock L28 cam for sale.
Also tagged with one or more of these keywords: L28, Turbo, P90, Cam, Manifold
