Brake Boosters - Where To Buy? Alternatives From Other Cars?
12 replies to this topic
#1 Dan260Z
Dan260Z
  • 150 posts
Posted 07 June 2016 - 01:05 PM
Looking for a new or rebuilt one for my 74 260z build - seen them on evilbay for around $300 which seems a bit steep... anyone know of a better deal?
Or... if there's anything bolt-on (or minimal mods) from another car that achieves similar assistance?
OR..... if there is such thing as a booster rebuild kit?  Happy to get my hands dirty to clean it up and paint it, etc, but if the innards are buggered and can't be replaced there's no point (nfi what condition it's in, I vaguely remember it working when I drove the car last in 2007)  No doubt there's something made of rubber in there that will have degraded over the past 42 years and is worth replacing.
#2 andyk_79
andyk_79
  • 658 posts
Posted 07 June 2016 - 01:41 PM
I can't remember the cost but mine was reconditioned by an outfit in Sydney (can't remember who either which is not real helpful !!).  They often require blasting and painting as well as all the diaphrams replacing so reco is up around the same price.  $300 seems pretty reasonable to me.
  • gav240z likes this
#3 gav240z
gav240z
    Administrator
  • 12,743 posts
Posted 07 June 2016 - 02:10 PM
A few brake places in here might be able to help?
http://www.viczcar.c...der-right-side/
http://www.viczcar.c...heel-cylinders/
#4 dat240z
dat240z
  • 1,119 posts
Posted 08 June 2016 - 11:29 AM
I used an R33 gtst brake booster which bolted straight onto my 15/16 MC. should be easy and cheap to find
#5 KatoKid
KatoKid
  • 1,712 posts
Posted 28 June 2016 - 02:36 PM
/\ /\ /\ what he said.
#6 600Z
600Z
  • 280 posts
Posted 23 October 2016 - 07:16 PM
Hi guys,
I take it the R33 brake booster will has the same stud spacing as the original 260z ones and will bolt straight in place?
Or is there other better ones to fit?
I'm looking at doing the 4 piston hilux front and r31 rear to two of our zeds at the same time and will also upgrade to the 15/16" master cylinders at the same time.
Justin
Edited by 600Z, 23 October 2016 - 07:22 PM.
#7 blu260z
blu260z
  • 274 posts
Posted 23 October 2016 - 08:06 PM
Only certain r33 bosters fit. I purchased a BM57 r33 booster and the hole centres were off. I just transferred the measurements into the firewall and re drilled them. The BM57 r33 master cylinder is very good aswell as its the largest at 1 1/16" used in the r33 GT-R all that was needed was new lines from the master cylinder to the splitter.
Chris
#8 600Z
600Z
  • 280 posts
Posted 23 October 2016 - 08:55 PM
Thanks Chris, I suppose I could also open the booster up and change the mounting studs to suit as well though a bit more stuffing around.
#9 blu260z
blu260z
  • 274 posts
Posted 23 October 2016 - 09:26 PM
It is very tight up under the foot well in the zed's. Pretty certain I was stuck upside down at some stage!!! ☺
#10 zeds4ever
zeds4ever
  • 870 posts
  • Tagline:Old Member
Posted 23 October 2016 - 10:03 PM
The 280ZX is a bigger unit 9" as opposed to the smaller 260Z from memory but same bolt pattern as 260Z . I bought a second hand one then took it to Penrith brake & clutch who repaired it for $200 , I used a  1" brake unit which all bolts up the same.
Also fitted the Hilux front brakes but not the vented type as I didn't like using the washers you have to use to get them to fit correctly . The rotors I fitted were the drilled & slotted units .
                      Regards : Alan .
#11 600Z
600Z
  • 280 posts
Posted 23 October 2016 - 10:49 PM
Lol yes Chris there sure isn't much room under the dash of them at all.
Alan do you have much feel with the 1" master cylinder?
Justin.
#12 zeds4ever
zeds4ever
  • 870 posts
Posted 24 October 2016 - 01:34 PM
From the few times that I've sneeked it around the block , they have good feel , not rock hard & wont put you thru the windscreen .
I'm happy with them , remembering I have a big 280ZX motor in.
                                                       Regards : Alan .
#13 600Z
600Z
  • 280 posts
Posted 24 October 2016 - 05:22 PM
Thanks Alan, sounds like it could be the go.
