Oil Pan Clamp (Keeper)
3 replies to this topic
#1 Andrew_L26
Andrew_L26
  • 389 posts
  • Tagline:That Purple Zed
Posted 06 June 2016 - 03:04 PM
Hi all, So I'm doing my oil pan gasket at the moment and my oil pan has this thing on it (well the black part anyway)
I'm wondering what the point of it is as it only goes around one corner of the oil pan.
Cheers,
Andrew
#2 dat2kman
dat2kman
  • 4,030 posts
Posted 06 June 2016 - 04:01 PM
There are a couple of bits of this,
It helps spread the load of the bolts and helps to make a better seal of the gasket, usually installed dry.
If using sealant, ( Three Bond is best) no real need for them, but seal both sides of gasket
#3 gav240z
gav240z
    Administrator
  • 12,386 posts
Posted 06 June 2016 - 04:46 PM
I find it weird that it only goes around half of the sump though? Wouldn't it be better if it went all the way around?
  • Andrew_L26 likes this
#4 Andrew_L26
Andrew_L26
  • 389 posts
Posted 07 June 2016 - 07:07 PM
That's what I was thinking, I put a proper gasket in but it just seems pointless going around half of it...
