Help! - Seized L26?
Rebuild Engine L26 Triple carb Twin su 260z 1976 Forged Internals Piston
23 replies to this topic
#21 Retro Z
Retro Z
  • 1,398 posts
Posted 30 May 2016 - 05:58 PM
Also do you have 12v at the coil+ while cranking and when the key is in ON position
#22 PB260Z
PB260Z
    Peter (PB)
  • 3,237 posts
Posted 30 May 2016 - 07:03 PM
Are you speaking from experience PB ;)
Hmmm, I have no idea what you mean ;-)
Edited by PB260Z, 30 May 2016 - 07:04 PM.
#23 Ahoysandy
Ahoysandy
  • 67 posts
  • Website:http://www.facebook.com/wideopenshutter
Posted 30 May 2016 - 09:27 PM
We got it sorted!! i was fiddling around a little and used a bit of Nulon 'Start Ya Bastard' in the carbs and that helped it want to fire EVEN more and almost run on this alone, which made me think its not likely timing but instead fuel. checking all my lines i found a small leak between the pump and the rail which i clamped up with some new hose. It now RUNS!! must've been a fuel pressure leak, i mean, i runs horribly because theres no exhaust and hasn't been timed, but i'll get to that soon :) thanks for the help here guys, i'll no doubt be back soon in this thread when the next problem occurs!
#24 PB260Z
PB260Z
    Peter (PB)
  • 3,237 posts
Posted 30 May 2016 - 09:40 PM
Good result, great feeling when find the cause of a problem.
PB
Also tagged with one or more of these keywords: Rebuild, Engine, L26, Triple carb, Twin su, 260z, 1976, Forged, Internals, Piston
