Hi Community,
New owner to the Z cars, I have a 8/82 280ZX 2+2  Auto Box which I badly need the diff mount rubber, I cant find anywhere. Also does anyone know who can recondition rear calipers or possible have some for sale, mine are worn out and rattle badly on the slides.
Thanks in advance,
Tim
Share this post
Link to post
Share on other sites
Genuine Nissan for the diff mount.
Better brakes in mordiallic, Vic to rebuild your calipers.
Share this post
Link to post
Hi Lurch, Nissan cannot get them genuine any more Part number 55476 - P6500. like I said I have hunted hi and low. Thanks for the brakes tip. Cheers
Share this post
Link to post
I can get the diff mounts re-rubbered, to as new.
I do need a few mre items in rder fr the factory that does this, to start.
Minimum number f 10 items are required.
Share this post
Link to post
Yeah if you do that diff rubber see if you can get the rear k frame rubbers as well cause there the only ones i didnt do on my rebuild.
And and the steering rack, this all being on a 280zx.
Put me down for 1 though
Share this post
Link to post
Got pricing back for re-rubbered in 80 Durometer hardness ( stiffer than stock, eqivalent to original Nissan Competition items) for, gearbx mounts, engine mounts, and diff mounts.
They get thouroughly cleaned, degreased, all old rubber ground off, surfaces prepped, new compound rubber is then poured inside, the mounts have paper coated "dams" fitted, and the new mounts have no voids in their middles.
$150 per item plus postage.
Last I had these done, 12 years ago, they were around the 75-80$ mark per item.
Do I go ahead and get the few I have here done???
Share this post
Link to post
Hi Community,
Thanks in advance,
Tim
Aren't there two separate diff mounts for a 280ZX?
One at the front of the diff where the insulator sits between the bottom of the diff and a cross member(presume this is the one you are referring to Tim)
The other at the top rear of the diff where the insulator then bolts to the chassis.
There are two types of rear mount/insulator available. Depends if you are running an R180 or R200 diff.
Cheers.
Share this post
Link to post
Hi
I would be in for one. Don't need it right now but am sure will need one at some time in the future. So will put it on the shelf for a rainy day.
PB
Edited by PB260Z
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
