Car Weight And Weight Distribution
4 replies to this topic
#1 Missinglink
Missinglink
    Member
  • PipPip
  • 29 posts
Posted 11 April 2016 - 06:53 PM
Hi All,
Just though I would throw up some info in regards to car weight and distribution. Though it might be handy for anyone looking for numbers when building a Zed.
I just finished a first pass corner weight setup on the car and found out the following...
Car Specs:
Model : 1972 240Z
Engine : 302 Windsor with Alloy heads, intake and water pump.
Gearbox : Supra 5 Speed Alloy case with steel sandwich plate.
Rear end : R200 with mechanical LSD.
Suspension and Brakes : Full AZC Setup.
Steering : Subaru Power Steering rack and Ford Power steering pump.
Wheels and Tyres : 17*9 3 Piece Rims with 235/45/17 RE011 Bridgestones
Body Mods : Fiberglass Bonnet
Additional stuff : Half cage (welded in), Evo 8MR Seats, Full Carpet Trim, Re-enforced and extended chassis rails, Unknown body work (included small steel flares and no idea how much filler)
Results:
Cross Weight @ 50%
Car Weight (Including half a tank of Fuel and all fluids + Driver) : 1197.5 Kg
Weight Distribution (Driver In) : 51% Front, 49% Rear.
Car Weight (Including half a tank of Fuel and all fluids) : 1127.5 Kg
Weight Distribution (Driver Out) : 52% Front, 48% Rear.
If anyone wants more info or wants to add with their own, go for it.
Edited by Missinglink, 11 April 2016 - 07:30 PM.
#2 260DET
260DET
  • 2,309 posts
  • Tagline:Tribal Elder
Posted 11 April 2016 - 07:05 PM
Driver out it looks like it, driver in is more relevant. With yours driver in would show pretty good weight distribution, maybe 48% F 52% R?
#3 Missinglink
Missinglink
    Member
  • PipPip
  • 29 posts
Posted 11 April 2016 - 07:27 PM
Righto, fixed to show numbers with Driver in and Driver out.
#4 TomC18
TomC18
  • 124 posts
  • Tagline:Old Racer
Posted 12 April 2016 - 07:40 AM
Rolled the race car over the scales at PI on the weekend with 25-30l of fuel and heavy battery in the very back as i haven't replaced the Odyssey yet
Fr 465kg total 925kg so 50,25/49.75% driver will shift it back a little, but battery will probably go the other way
#5 260DET
260DET
  • 2,309 posts
Posted 12 April 2016 - 08:34 AM
From memory the 260Z I had with FJ20ET engine and gearbox, R180, driver in, was 48%F, 52% R. Have not checked the 280ZXV8 yet.
