L-Series Valve Springs For High Lift Cam
3 replies to this topic
#1 Groundhog
Groundhog
  • 210 posts
Posted 11 April 2016 - 09:19 AM
I've heard mixed reports about valve springs breaking when using a high lift cam,
In particular the inner valve spring.
What type of valve springs are people fitting?
I have a cam with 0.490" In/Ex lift.
#2 Lurch ™
Lurch ™
  • 5,662 posts
Posted 12 April 2016 - 12:57 PM
With that lift, Is the cam a works 72deg item?
If so, STD valve springs will be fine.
#3 Groundhog
Groundhog
  • 210 posts
Posted 12 April 2016 - 01:29 PM
The cam I have the option of using is a TIGHE 492C.
It comes already fitted to a reconditioned N42 head.
I need to decide whether to go with this cam or change it for a 72 degree item.
http://tighecams.com.au/cars.htm
Edited by Groundhog, 12 April 2016 - 01:29 PM.
#4 dat2kman
dat2kman
  • 4,061 posts
Posted 12 April 2016 - 03:18 PM
Do you mean tighes 462c grind, as per their tables?
492 s not shown.
For a mild grind, the Performance brand springs are fine.
Does it have springs fitted?
We can pull them out and comare stock to the Performance RR4'
I have plenty of both!
Edited by dat2kman, 12 April 2016 - 03:20 PM.
