Wheel Alignment
4 replies to this topic
#1 alanwil
alanwil
  • 30 posts
Posted 21 March 2016 - 06:07 AM
I know this has been covered before. Someone asked about 240Z track wheel alignment as they couldn't get their car to steer well. Lurch gave measurements of
Front Castor = 5deg positive - the more the better. (L&R)
Front Camber  = Start at 3.5 deg negative & adjust from there, via tyre temps (L&R)
Front Toe = 1 mm toe in (L&R)
Rear Camber = 2.4 (L&R) probably too much, but what are the tyre temps reading?
Rear Toe = 1 mm toe IN (L&R). Toe out makes IRS cars nervous in the rear.
According to the person asking for help this made a big improvement. Would this be the same for a road car or would I need something different? I recently went to get an alignment check and was told it couldn't be done because a 240Z wasn't on the computer data, as it was too old. I do have some old style alignment guys around but would like to have some specifications to take to them.
  • Jap Metal likes this
#2 zeds4ever
zeds4ever
  • 868 posts
  • Tagline:Old Member
Posted 21 March 2016 - 08:04 AM
                                                          Can anyone supply the spec's for 260Z S30 models please .
        Regards: Alan
#3 HKSZ
HKSZ
  • 251 posts
Posted 21 March 2016 - 05:42 PM
You will never get 3.5 neg camber with out adj arms.
That said it would be terrible on a daily driver too.
1 to 1.5 is plenty on a road car
0 to .5 on rear
#4 alanwil
alanwil
  • 30 posts
Posted 21 March 2016 - 09:03 PM
Thanks for the help. Are the other measurements ok?
#5 HKSZ
HKSZ
  • 251 posts
Posted 21 March 2016 - 10:13 PM
Your front end alignment guy will only ever adjust the ft toe ( until you put adj castor rods, camber plates etc in)
Imm toe in is good for stability.
o or 1mm toe out helps turn in but the car can become darty at high speed.
